First post, by digicube
I use CHKDSK /R and Norton Disk Doctor but I keep getting "lost delayed-write data" error when writing files onto the disk. It doesn't happen on other disks, so I assume it's bad sectors. I also cannot format the disk to NTFS, only FAT.
Is there a better software than can check and mark bad sectors?
Reply 1 of 1, by digicube
A workaround I did is resize the disk partition to 160MB and not use the first 30MB since the error occurs at the 25MB mark.
