First post, by l33tl4m3r
Had been gettingthe fastflex.c error, correctly mounted the cd and that went away...
NOW when I try to start the game i get "Halted File file\flex.c, line 22"
I've tried a few things, but found no topics on this error... anyone have an idea?
Reply 2 of 7, by l33tl4m3r
both were set true by default - have been playing with cycles and dosbox config, nothing as of yet...
I have not seen this specific error reported on any threads so far...
Reply 3 of 7, by l33tl4m3r
Except for Ben on the Ultima 8 thread...
I'm ugly on the inside too...
Reply 4 of 7, by l33tl4m3r
Well... I went ahead and instead of copying the files from CD just installed directly from cd and it works fine now...
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
mounting problem then. Glad to know you solved it
Water flows down the stream
Reply 7 of 7, by l33tl4m3r
🤣... first time using dosbox...
It'll get better... now I am going back and installing ALL my old dos games...
And so far I have had no troubled with skipping or sound or anything... even the video is synched fine...
Running with;
AMD 2500+
1GB
