Jetfighter2
Reply 20 of 25, by Pan
Hmm, I just downloaded and compiled the latest CVS Dosbox code and JF2 definetely does not work with it. So if a patch has been applied to resolve the problem, it doesn't work 😀
Reply 21 of 25, by Pan
Actually, no, I'm mistaken. It does work. But the first time I tried it, it froze up like before. The error printed on the console is shown below
Illegal read from d030f7b0, CS:IP 2ee: 1cf9
Illegal write to d030f7b0, CS:IP 2ee: 1cf9
Very unusual. I tried it three times afterwards and it worked fine each time. I was using the "Instant Action" mode
Reply 22 of 25, by wd
Rank DOSBox Author
DOSBox Author
If it's reproducable, please post it in the dosbox forum.
Maybe it was just misconfigured, or something with your build.
Reply 23 of 25, by Pan
I gave it a second go with a new CVS build and it appeared to run fine every time I tried it. I'll keep an eye out in the future for any problems, but it appears fine 😀
Reply 24 of 25, by thanhlinh
i need some links to download Dos games , please.
Reply 25 of 25, by eL_PuSHeR
You better ask elsewhere. 😠
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
