3Dfx Voodoo 2 PCB SLI Bridge / SLI Cable
Reply 20 of 106, by matze79
Also have 40 Pin Cables from Dreamblaster in Rainbow Colors 😀 but they are very short ~20cm
Reply 23 of 106, by matze79
1.44 MiB
871.13 KiB
i personally like Non-3Dfx Logo more, but only got Few pieces of them (minimum order size)
Reply 24 of 106, by matze79
3Dfx Build from ChrisK from dosreloaded.de:
Reply 25 of 106, by Aebtdom
What a sweet rig!
Looks really nice with the lighting inside.
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 27 of 106, by Aebtdom
Still, to make it more time accurate. I would prefer this logo.
Builds:
Reply 29 of 106, by matze79
It can`t be time accurate because it did not exist back then
still have some left, if someone is interested write me for 3dfx logo version.
i`m Getting rid of excess now 😀
808.1 KiB
GPL-2.0-or-later
1 Kit is one big and one small bridge + headers, self solderable.
Reply 30 of 106, by wirerogue
i finally got mine installed. works perfect. thank you.
here are some photos.
321.83 KiB
1.6 MiB
1.68 MiB
1.7 MiB
Reply 32 of 106, by wirerogue
chrismeyer6 wrote on 2021-05-18, 03:20:
That looks awesome in your system. Just curious but was there a difference in your benchmark results compared to the regular sli cable?
i forgot to test it before but, it sure seems faster.
Reply 33 of 106, by chrismeyer6
Cool. My assumption would be with the pcb based bridge you'd have better signal integrity than the ribbon cable. I remember reading something similar back in the day with Nvidia sli where the pcb bridges had less micro stutters than the flexible bridges I read that on Tom's Hardware or maybe antech one of those sites.
Reply 34 of 106, by Aebtdom
I've recieved mine today. Thanks Matze79!
When I have the time to solder it together I also will do some testing.
1.03 MiB
Builds:
Reply 35 of 106, by matze79
No kits left 😀
Nice you like it
Reply 36 of 106, by matze79
https://www.serdashop.com/3DVideoBridge
Now listed on Serda Shop 😀
Reply 37 of 106, by feipoa
Installed mine in my Nec Proserva with dual P233 MMX chips. Looking slick!
A word of caution - it is possible to plug in the connector with the mating pins off by a single pin width. If you are at a weird angle trying to install it, best to get your eyes head-on to avoid this.
845.78 KiB
Reply 38 of 106, by matze79
Nice System, i really would fill up the RAM Slots 😀 it looks sooo empty!
Reply 39 of 106, by feipoa
matze79 wrote on 2021-05-30, 18:05:
Nice System, i really would fill up the RAM Slots :-) it looks sooo empty!
I agree, but there are two reasons I have not filled them.
1) There is no option to ESC the POST memory test and it takes a long time with 512 MB vs. 256 MB.
2) There is only one brand of RAM which worked well with the memory timing hacks implemented and I only have 4 sticks of them.
