First post, by Putas
Is it possible new keyboards are not compatible with old motherboards?
Bought a cheapest new PS/2 keyboard. Plug it into my K7 mobo, no good. Plug back my old keyboard, works.
Tried the new keyboard in Ryzen mobo, and it works just fine.
How is this possible?
Reply 1 of 4, by Cyberdyne
Only logical explanation is maybe, that the voltage is off. so measure with multimeter. I know that very old keyboards with AT to PS/2 converter cable may have too large power draw. or even litle timing issues. But a K7 PS/2 and Ryzen PS/2 have identical protocols. It is just impossible. Bu well sometimes, just something just do not mix, try another brand cheap keyboard then. Well cheapest mouses and keyboards and accessories have been had problems with power requirements and not following protocol specs to the letter. So there yo have it.
Reply 2 of 4, by chinny22
As its a new keyboard I wonder if its actually a HID USB style keyboard and the PS2 plug is just a passive adapter, much like those cheap PS2 to USB adapters.
I could see some cheap Chinese company doing something like this, and to be fair would be fine for some boring XP or later office PC, still crap though if that is the case
Reply 3 of 4, by douglar
I have had a case where a slot A athlon motherboard would not post when connected to a old Din 5 lexmark keyboard, but I’ve necer seen an old motherboard have prpblems with a newer keyboard.
Reply 4 of 4, by Putas
Would be interesting to check if it is a badly converted USB. On the other hand, I am considering RMA to clarify/force the chain to be clear on compatibility.
