First post, by Sphere478
- l33t++
So I downloaded forceware 81.98 but I have artifacts in sim city 2000 I'm wondering if I should try a older driver? thoughts?
On Phil's archive, it looks like the earliest drive that includes the 6200 is 66.94: https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
Repo Man11 wrote on 2021-02-12, 03:10:On Phil's archive, it looks like the earliest drive that includes the 6200 is 66.94: https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
thanks!
is the earliest usually the best? or the very next one?
IMO the driver that works best for what you're doing is the best one. Sometimes an older driver will solve an issue, sometimes a newer one will. Very early Nvidia drivers seem to work better with older hardware.
i tried that driver it seems to be too old no 6200 support will try next one
it seems none of those have 6200 I don't think they are full driver packs
any other download links for 66.94 that includes 6200 support none of the ones I find will finish the download they all crash or never download
See sticky thread for VOGONS Drivers?
http://www.vogonsdrivers.com/index.php?catid= … &menustate=14,1
swaaye wrote on 2021-02-12, 18:13:See sticky thread for VOGONS Drivers?
readme in the 66.94 from vogons says adapters supported are:
NVIDIA RIVA TNT NVIDIA RIVA TNT2 NVIDIA RIVA TNT2 Pro NVIDIA RIVA TNT2 Ultra NVIDIA Vanta NVIDIA Vanta LT NVIDIA RIVA TNT2 Model […]
NVIDIA RIVA TNT
NVIDIA RIVA TNT2
NVIDIA Vanta
NVIDIA Vanta LT
NVIDIA RIVA TNT2 Model 64
NVIDIA RIVA TNT2 Model 64 Pro
NVIDIA Aladdin TNT2
NVIDIA GeForce 256
NVIDIA GeForce DDR
NVIDIA Quadro
NVIDIA GeForce2 MX
NVIDIA GeForce2 MX 200
NVIDIA GeForce2 MX 400
NVIDIA Quadro2 MXR
NVIDIA Quadro2 EX
NVIDIA GeForce2 GTS
NVIDIA GeForce2 Pro
NVIDIA GeForce2 Ti
NVIDIA GeForce2 Ultra
NVIDIA GeForce2 Integrated GPU
NVIDIA Quadro2 Pro
NVIDIA GeForce4 MX 420
NVIDIA GeForce4 MX 440
NVIDIA GeForce4 MX 440-SE
NVIDIA GeForce4 MX 460
NVIDIA Quadro NVS
NVIDIA Quadro4 500 XGL
NVIDIA Quadro4 550 XGL
NVIDIA GeForce4 MX Integrated GPU
NVIDIA GeForce4 MX 420 with AGP8X
NVIDIA GeForce4 MX 440 with AGP8X
NVIDIA GeForce4 MX 440SE with AGP8X
NVIDIA Quadro4 NVS with AGP8X
NVIDIA Quadro4 380 XGL
NVIDIA Quadro4 580 XGL
NVIDIA GeForce3
NVIDIA GeForce3 Ti 200
NVIDIA GeForce3 Ti 500
NVIDIA Quadro DCC
NVIDIA GeForce4 Ti 4200
NVIDIA GeForce4 Ti 4400
NVIDIA GeForce4 Ti 4600
NVIDIA GeForce4 Ti 4200 with AGP8X
NVIDIA GeForce4 Ti 4800
NVIDIA GeForce4 Ti 4800 SE
NVIDIA Quadro4 700 XGL
NVIDIA Quadro4 750 XGL
NVIDIA Quadro4 900 XGL
NVIDIA Quadro4 780 XGL
NVIDIA Quadro4 980 XGL
NVIDIA GeForce FX 5800
NVIDIA GeForce FX 5800 Ultra
NVIDIA Quadro FX 1000
NVIDIA Quadro FX 2000
71.84 says:
NVIDIA RIVA TNT
NVIDIA RIVA TNT2
NVIDIA Vanta
NVIDIA Vanta LT
NVIDIA Aladdin TNT2
NVIDIA GeForce 256
NVIDIA GeForce DDR
NVIDIA Quadro
NVIDIA GeForce2 MX
NVIDIA Quadro2 MXR
NVIDIA Quadro2 EX
NVIDIA GeForce2 GTS
NVIDIA GeForce2 Pro
NVIDIA GeForce2 Ti
NVIDIA Quadro2 Pro
NVIDIA Quadro NVS
NVIDIA GeForce3
NVIDIA Quadro DCC
No 6200.. 🤔 am I downloading the non full driver or is it just too early of a driver
The 6200 is supported (and the 6600/6880). The readme is just not updated. Look at the bottom of NVAGP.INF file.
lost77 wrote on 2021-02-12, 22:34:The 6200 is supported (and the 6600/6880). The readme is just not updated. Look at the bottom of NVAGP.INF file.
I tried both of those versions (though not the specifically the vogons downloads) it said standard graphics adapter in device manager after install I’m not home atm to try the vogons ones specifically but those versions didn’t install the 6200 driver when downloaded elsewhere.
Try following the guide here: https://www.evga.com/support/guides/9X_Install.pdf
I think your problem is that the PCI version of the 6200 was released several years after the AGP and PCI-E version. The GPU is the same though so just force install the older drivers.
