First post, by iVirtualZero
My PSU is an EVGA 450Watt (450BT) 80 Plus Bronze PSU. It randomely stopped working and then it started working after couple of hours. Is this of the wrong spec? Is this providing enough power to my Socket 370 Build? And do Retro PC’s consume a lot of power?
My build
450 Watt EVGA PSU 80Plus Bronze PSU
Socket 370 Dual CPU Support Motherboard
Dual Tualatin 1.4ghz CPU’s
1gb ram
Ti 4600 CPU
Matrox Millennium 2
SoundBlaster AWE64 ISA Sound Card
SoundBlaster Audigy 2 PCI
120gb SSD with 98SE
120gb IDE HDD
8fans including 2gpu and 1psu fan.
Drives:
500gb IDE HDD
2 DVD Drives
Floppy Drive
USB Floppy
May just replace the AWE64 ISA Card with an Orpheus + PCMidi with a Dreamblaster X2 Module. May also chuck in PCI Voodoo 2. If i can get it for a good deal. So what PSU do you recommend? And can they easily be found for a good price?
Reply 1 of 12, by mothergoose729
No. Don't spend more than 40$ on a PSU for a socket 370 build. It is not impossible for a modern PSU so spontaneously fail.
Socket 370 uses almost exclusively 5v power. Buy a decent enough PSU with 20amps on the 5v rails. That is all you need. That is the best you can do these days.
Reply 2 of 12, by iVirtualZero
mothergoose729 wrote on 2021-02-13, 04:38:
Even with my Dual CPU, GPU and Dual Soundcard build? Can you recommend me a great modern PSU for this old build?
Reply 3 of 12, by debs3759
It's only worth paying extra for a more efficient PSU if you use it enough to recoup the cost in power savings. As long as you have enough on each rail, as mother goose said, that is the most important thing, from the system's point of view.
Reply 4 of 12, by iVirtualZero
debs3759 wrote on 2021-02-13, 04:44:
So does wattage not matter with Socket 370 builds? What modern psu’s do you recommend? And why did my 80 plus PSU fail?
Reply 5 of 12, by debs3759
I doubt anyone can tell you why the PSU failed based on just a text based question. I would say 450W is fine if it has enough on each rail, which I can't comment on. It's what I would aim for on most early ATX build, simply because, 80+ or not, a PSU that is only pushing half what it is capable of should be at its most efficient. Later systems, I go for 600W if not benching GPUs, and minimum of 750 if benching GPUs. That's where 80+ Platinum becomes most cost efficient.
Reply 6 of 12, by mothergoose729
iVirtualZero wrote on 2021-02-13, 04:50:
5v power is all that matters. Modern PSUs are rated for high wattage on the 12 v rails. The 1000 watt units won't do you much better than a 450 watt unit.
iVirtualZero wrote on 2021-02-13, 04:42:
The only other option if you want more power is to buy an old stock power supply with more wattage on the 5v rails. They definitely exist, but I wouldn't use them.
Your dual CPUs are rated for about 62 watts put together. 20amps gives you 100 watts of 5v power to work with. With your GPU it's really close.
Reply 7 of 12, by iVirtualZero
mothergoose729 wrote on 2021-02-13, 06:40:
5v power is all that matters. Modern PSUs are rated for high wattage on the 12 v rails. The 1000 watt units won't do you much be […]
Thanks are there any readily available new psu’s with this spec?
Reply 8 of 12, by iVirtualZero
debs3759 wrote on 2021-02-13, 05:26:
It’s working again. My PSU is an EVGA 450Watt 450BT 80 Plus Bronze PSU. Is this of the wrong spec?
Reply 9 of 12, by frudi
EVGA's website says the 450 BT can do 18 A on the 5 V rail, with a combined max output of 90 W on 3.3 V and 5 V rails together. With just the pair of 1.4 GHz Tualatins pulling over 60 W at max load by themselves, then adding the consumption of RAM, video cards, sound cards and motherboard components, you're probably pushing the PSU to or beyond its limit for 5 V and 3.3 V rails.
I would recommend either getting a new PSU with a more powerful 5 V rail, or refurbishing an older PSU from the Athlon XP era. I know Corsair's current TX and TX-M series can do 25 A @ 5 V, at least on 600 W+ units, I'm not sure about other brands or models.
Reply 10 of 12, by iVirtualZero
frudi wrote on 2021-02-13, 17:24:
Thanks, i thought i was pushing this beyond what it could do. I’d prefer a modern psu due to it being new with it’s extra safety features. Guess i’m going with the Corsair TX series. Is the Corsair TX850M 80Plus Gold a good choice? Weird how it costs less than the 650watt version.
Reply 11 of 12, by frudi
I think all TX-M models from 650 W and up have the same specifications for the 5 and 3.3 V rails, so go for whichever model you can get for cheapest. Just skip the 550 W and lower models, since those supply only 20 A @ 5 V.
Also try searching this forum for older threads; I remember the topic coming up before so if you find some of the previous discussions some other members might have given more suggestions for other (namely cheaper) models. Not that the TX-M is a bad choice, quite the opposite, it's just not exactly cheap, especially with all the current hardware shortages.
Reply 12 of 12, by iVirtualZero
frudi wrote on 2021-02-13, 18:03:
Thanks i’m already reading some other threads.
