The plate was straightened in exactly the same way as I came up with. Unfortunately, I can't show the effects, but what I broke, has been fixed. : D
The attachment compressing.jpg is no longer available
Something about choosing the right motherboard - for me the most important element of the set next to the RAM. As you know, i create build in micro atx housing. Below are some ATX motherboards that I think look "cool".
The attachment kolarz.jpg is no longer available
Unfortunately, for the micro atx format, the choice is not so interesting. The only thing that caught my eye. Additionally, some of these boards are almost impossible to buy
The attachment kolarz matx.jpg is no longer available
Considering both any purchase possibility and a few other factors, after more than two months of searching, I bought this.
The attachment Biostar M&NCG 400 v.7.2.jpg is no longer available
"How did I get this board?" It is more interesting story than you might think. Based on the auction archives, I knew that this board even exists. I found one offer with a computer that, according to the description, had it inside, unfortunately it turned out that it was sold and the seller forgot to remove the offer. very day I looked through all ads with desktops in Poland up to + -50 $ in the hope that one of them would have it. Of course, it got bored me after a long time. I tried to change tactics. In the archives of the auction site I found an offer with this motherboard . The offer took place a year ago. I asked the seller to give me the buyer's email address. I wrote to buyer and asked if the motherboard was in use. I was supposed to offer $ 25 right away. However, the seller (buyer 😀) immediately said he don`t use it and he wanted to sell it for $ 12. I didn`t negotiate the price ... 😀 The happiest moment while building this setup. It is a pity that he said that I have to wait 2 weeks for him to come home and then he will be able to send the parcel ...
Pros:
- the only important OC setting this board does NOT have is to decrease the multiplier (to increase the memory frequency while keeping the CPU frequency at the same level)
- no atx12V power plug - which is actually a disadvantage, but priority for this build is to keep a "clean look", a lot of cables in the housing make me sick
- atx20pin power plug is on the right side of board - the same reason as above
- this is not the usual red that we know from MSI boards or radeon cards. It's like "cherry red". It looks really great and I will try to capture this effect in photos.
- diferrence in performance between M7NCG and Asus with exacly the same freq and timings - 55s vs 45s in SuperPi 1M (A very pleasant surprise)
- lower idle temps - i don`t know if it was an illusion, but i swear - there was 37 degrees on asus and 29 on Biostar. Biostar has 37 only in BIOS, when i log into windows, temps begin drop to 29. It is impossible that it was the fault of the block clamp because it was very tight with screws and I checked it several times
The only disadvantage I can think of - no mounting holes for CPU Waterblock - my block uses screws.
During my search, I also posted a purchase ad on my local forum. One user told me to avoid Biostar boards from that period. He said he used to mount these boards in computers made to order for companies and half of them (!) Went back for warranty repair.Whether it was the fault of the capacitors or something else - I don't know. I suspect that those that have survived to this day will live forever. The person who sold me the board replaced 3 capacitors. In general, I wanted to replace all the capacitors around the CPU with polymer ones. Unfortunately, I can't find any with matching parameters. I also want to install a radiator on a mosfet, one of them is very hot above 1,9V vcore (which is normal, but this one burned me so much that I had to pour water on my finger from the tap 😀 )
I'll have to make a new block top. For now, I'm using a temporary processor clip. This is what the clip on my test socket looks like 😀
The attachment CPU Bracket.jpg is no longer available
