First post, by C0deHunter
I get really nauseous playing old DOS FPS , specially when playing Hexen.
Is there a fix for these games?
thanks!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 1 of 8, by darry
C0deHunter wrote on 2021-02-16, 02:22:
thanks!
Maybe one of the source ports offers some options on that front .
Incidentally, I remember the first time that I saw someone playing Wolfenstein 3D. I got quite nauseous . I was lucky as that was an isolated occurrence, but I remember the unpleasantness . I really feel for you and hope that you find a solution .
Reply 2 of 8, by Cyberdyne
I don´t, but my friend got really nauseous when we played Wolfenstein 3D and Doom on my P3 what is connected to a 65" (I know it looks like Minecraft in steroids, but I like it.)
I think these are the same people that get seasick easily. I have had no problem with that, only on time when I took a 3 day cruise to Sweden, and I was intoxicated and there were like 5 meter waves and a real storm outside. The ship was rocking like a motherf...er.
But yes, only source port.
PS. I really liked Doom gun bobbing, but never liked the Quake back and forth thing, it felt like they took a step back.
Reply 3 of 8, by mrau
there was an old trainer which offered to disable that - i believe its a very simple edit, just have to know location - a 1 d table is beinge traversed hence and forth to offer the value of the shift in current frame (i believe so, did not really check myself)
Reply 4 of 8, by C0deHunter
Thanks for your responses, I am playing these on a real vintage computer, so the source ports are out of the question. But thanks for the comments nonetheless.
Reply 5 of 8, by dr_st
See if you can get ViTi95, who works on FastDoom, to implement this feature:
FastDoom. A new Doom port for DOS, optimized to be as fast as possible for 386/486 personal computers!
It looks like it may have something to do with player->bob and A_WeaponReady. Haven't actually looked deep enough in the source to figure it out, but it should be doable.
Reply 6 of 8, by Kerr Avon
Is there any medication you can get to counter motion sickness? Failing that, over the years I've read lots of posts from people who suffer from motion sickness when playing fast, first person games, and I've seen various solutions proposed, such as using a higher frame-rate, or altering the field of view (if the game supports a FOV option), but I don't remember if any of these were proven to work with anyone.
Would it help if you played in darkness (aside from the monitor screen, of course), as then your subconscious would be less likely to notice the difference between movement on the screen and the non-movement of everything else in your house (the walls, the keyboard, your desk, etc). Probably won't work, but might be worth a try.
Reply 7 of 8, by kmeaw
At the byte position of
Heretic: 61e6e
Hexen: 7b23c
Doom 1/2: 7506f
replace the bytes "c1 fa 02 89 51" with "33 d2 90 89 51" - the sequence should appear only once per binary.
It will remove both head and weapon bob from the game.
Reply 8 of 8, by Cyberdyne
Nice. How to make Doom play like Wolfenstein 3D. I will try it for just the fun of it.
