First post, by bjwil1991
A week or so ago, I received the Gigabyte GA-486AM/S motherboard that was missing the Dallas RTC chip and installed the replacement one temporarily to test it out.
Well, I plugged in the board, 1 stick of RAM, an ISA video card, the keyboard, and PC speaker and it did POST, but it froze up at the RAM count.
I then realized I put in only 1 stick of RAM and not 2 of them (4 RAM slots, 2 slots per bank), however, the board needs a new adjustable VRM and a jumper header for the CPU voltage since JP21 is either missing or wasn't added to the board back then.
I was surprised it POSTed with 1 stick of RAM installed for a second.
Reply 1 of 6, by Warlord
strong board
Reply 2 of 6, by SSTV2
486 CPUs are using 32bit external data bus, thus only one 32bit SIMM72 stick is needed for such system to successfully POST, wherereas socket 4/5/7+ CPUs are using 64bit external data bus and thus require at least two simm72 sticks 😉 There exists at least one S7 chipset that can interface a 64bit external bus CPU with a single SIMM72 stick with a performance penalty, but generally CPU data bus width should be equal to RAM data bus width per bank.
Reply 3 of 6, by TheMobRules
SSTV2 wrote on 2021-02-20, 05:27:
Yes, but this motherboard is kind of strange in that sense, all the valid memory combinations in the manual use either 2 or 4 banks/slots. Maybe some chipset limitation?
Other than that, it is a very fast board, ideal for a 5x86 or POD83.
Reply 4 of 6, by SSTV2
Interesting, it uses a UMC 888x chipset, which definitely can work with a single SIMM72 stick, I wonder if such two-sticks-per-bank configuration significantly increases memory throughput on that chipset.
Reply 5 of 6, by kixs
The board works fine with only one memory stick - I have three different versions of this board and all work fine.
There is no difference in memory throughput when used in pairs.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 6 of 6, by bjwil1991
Well, I got it sorted (somewhat). The DX2-66 CPU has a bent pin and after inserting my 5x86-P75 3.3V CPU in the socket, it boots up and goes through the memory count.
The other issue is the RTC Dallas chip that has the battery holder to swap out the batteries easily doesn't retain the settings, even though I inserted the chip the right way. I don't see any jumper settings that controls the normal/clear settings. The time is correct, but the date is off by 27 years.
