First post, by someperson42
I'm having trouble with this unusual Aureal Vortex 2 card in my AOpen AX6BC board:
https://imgur.com/a/N5gsdoi
I have a fresh install of Windows 98SE, and whenever I try installing any version of the AU8830 driver, the system freezes up. This happens no matter what PCI slot I have the card in. Can anyone help me?
EDIT: I think the card is likely the problem, because Puppy Linux won't seem to load with it installed, but it works fine without it.
Reply 1 of 3, by Intel486dx33
I had this problem with that card before. Its the driver. I forgot which driver to use but the one you are using is causing the lockup.
Reply 2 of 3, by someperson42
Intel486dx33 wrote on 2021-03-09, 11:31:
Do you have any idea which one it might be? I've tried a whole bunch of different drivers, including all the ones on the CD (yes, there are multiple for some reason) as well as from the Internet. Nothing seems to work.
Reply 3 of 3, by swaaye
2041 is usually the one to use. But it sounds like you have been quite exhaustive in your troubleshooting and I can't think of anything you haven't tried. And it's certainly not a problematic build for a Vortex 2.
