First post, by Tyrant
I'm rather new to this whole world I've just dipped into so please forgive my noobness. My computer seems to be running a lot slower than it should. I'm on a 98Se setup with over 700mb of RAM and 256mb VRAM and yet I can hardly manage to get games running on their lowest graphics setting despite having more than enough system requirements to handle max graphics. Even Doom 1 and 2 (not DOS version) suffer frame rate drops. I haven't yet updated my BIOS because I don't know how to. Here are my specs to the best of my knowledge, I've installed the Unofficial Service Pack 2.1
- Geforce FX5500 PCI graphics card
- Pentium 4 1.5ghz
- SiS 961 chipset (3x PCI slots no AGP or PCI-e)
I've gone though a few of the optimization guides and done things such as limiting my virtual memory to 512mb and they may have made slight differences. Everything seems to be running quite stable so I feel like this is the last hurdle. I have a suspicion that it may be the hard drives being older than 20 years, on another note when I tried to clear the dust out of my fan the following format and reinstall of 98 attempt happened MUCH faster (the whole fdisk and 98 install was much quicker). Since it's been unused for a while and sitting maybe it just needs a really good clean? Those things aside any input would be greatly appreciated. If you need more info on the specs just ask and I'll find out for you.
(Edit) Why probably solved: I found out that the new cheap FX5500 cards have crappy GPU's so that's most likely the source of my woes. Going to get a new motherboard and card and get back to you.
Reply 1 of 23, by Eep386
Pentium 4... did you make sure the thermal grease on your CPU is fresh? Old grease dries out over time and loses its thermal conductivity.
Pentium 4s react to high temperature by clock throttling.
You also made sure your heatsink + fan is attached properly too?
Reply 2 of 23, by Tyrant
Eep386 wrote on 2021-03-09, 23:50:
Hey thanks for your response, I actually rubbed a lot of it off because I didn't know what it was (and to read the model of the processor). I'll try cleaning the old stuff off and applying new grease.
Reply 3 of 23, by dionb
That could make a BIG difference if it's throttling. Another possibility (but far less impacting) is no chipset drivers installed. That would result in no DMA for HDD transfers, which give a very bad performance hit in anything loading.
Reply 4 of 23, by Tyrant
dionb wrote on 2021-03-10, 00:13:
I did enable DMA for each hard drive but whether or not it actually did activate or the box just ticked is uncertain. I'll try hunt down some chipset drivers but I don't think I had much luck last time I tried. Any particular driver I should be looking for? I'm getting varied results.
Edit: All I could find was an IDE Driver and a "HFDrive" driver do you think either of those will help?
Reply 5 of 23, by Tyrant
I cleaned it and applied new grease, how to I actually diagnose if it's throttling? I checked the temperature in the BIOS and it says 38c which is quite low but the games are still lagging.
Reply 6 of 23, by Joseph_Joestar
Tyrant wrote on 2021-03-09, 23:07:
Don't use more than 512 MB RAM when running Win98. You will experience all kinds of stability issues.
There are third party patches which can remedy this, but I haven't personally used them. See here: Best way to bypass the 512mb ram limit of WIN98SE
My retro stuff
Reply 7 of 23, by Tyrant
Joseph_Joestar wrote on 2021-03-10, 04:29:
Yeah that's why I limited the virtual usage to that setting but I think the workaround you speak of is in the unofficial service pack. Because before I used that the computer would give me the "windows protection error" when I went to install the graphics card drivers.
Reply 8 of 23, by darry
Tyrant wrote on 2021-03-10, 04:41:
AFAICR, you can also use Himemx.exe , which has an option to limit XMS memory, instead of Himem.sys . The option to limit it to 511MB XMS would be /MAX=532264
Reply 9 of 23, by Tyrant
I have noticed one thing if I turn the hardware acceleration to basic accelerator functions games like Doom will run really smoothly whereas they won't on full but games like Battlefield 1942 won't even launch which I think has to do with the fact that in basic mode the computer doesn't launch the nVidia Desktop Manager. So I'm thinking that the nVidia drivers are the cause my issues.
Edit: I have the latest driver installed and it's still doing it. I'm almost certain then that it's this. Anyone know any workarounds? My card was released Mar 17th, 2004 so I don't think I can use any older driver than then.
Reply 10 of 23, by zyga64
Tyrant wrote on 2021-03-10, 06:16:
Geforce FX 5500 is basically the same card as FX 5200, so you can use drivers which provides support for FX5200 only modifying .inf file in one place (well, in two places if you want card name to be displayed as FX5500).
To avoid big memory problem you can use excelent R. Roelw's PATCHEM - I'm using it successfully with 2GB of ram.
One more thing comes to mind. Is your DirectX release date >= than Nvidia drivers release date ? Just to be sure, that everything is supported.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 11 of 23, by Tyrant
zyga64 wrote on 2021-03-10, 06:44:
The driver is 2008 I think and the newest directx you can get is 2006 but I heard directx 9.c is notorious for instability. I want to try your idea on the fx5200 driver but I can't uninstall the current one (forceware 81.98), it won't let me. Any ideas?
Edit: I managed to get rid of it. Will try now to install the fx5200 driver. Do you know which exact one it is? (eg. 50.21)
Reply 12 of 23, by Oetker
Have you tried running Doom from pure DOS? That might help determine if it's a hardware issue or something with Windows/drivers.
Reply 13 of 23, by Tyrant
Oetker wrote on 2021-03-10, 07:04:
Thanks, it definitely is the crappy nVidia drivers
Reply 14 of 23, by Imperious
Use this to uninstall the drivers https://www.majorgeeks.com/files/details/driv … ofessional.html
Then get an earlier driver for Your card, maybe 45.23 works?
Don't get any idea Doom 3 will work acceptably on that system, it won't. Older games from 2001 and earlier should be ok.
https://download.cnet.com/NVIDIA-Forceware-45 … 8_4-102706.html
Reply 15 of 23, by zyga64
Tyrant wrote on 2021-03-10, 06:58:
Earliest with FX5200 support is 43.45 (a least on Phil's Computer lab site) https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
But people are recommending 45.23 as least troublesome. Iv'e used 45.23 with FX5500 AGP on Intel BX with Pentium 3 450 without any problems.
Reply 16 of 23, by Tyrant
zyga64 wrote on 2021-03-10, 07:18:
Man my comp really isn't liking this. I'm not sure if I'm doing it right but it's giving me all sorts of grief I think it's mixing up files. I don't think I properly removed all the nVidia files first from the older version first. What's the file I'm supposed to find when I hit have disk?
Edit: I was right I just had to properly remove all the old files and it's working now. Also what version of directx are you running? Also I checked directx I'm only getting half my available VRAM working through this driver. Is there a way to fix that or is that plenty?
Reply 17 of 23, by Imperious
Get the display driver uninstaller I linked to above.
Reply 18 of 23, by Tyrant
Imperious wrote on 2021-03-10, 07:49:
Yep I got all through that well. Just while I'm here are there any BIOS settings I should change to optimise my system?
Reply 19 of 23, by dionb
Tyrant wrote on 2021-03-10, 00:34:
You don't say exactly which board and chipset you have (961 is the southbridge, used by multiple northbridge chipsets), but this should be the IDE driver in any event, needed for proper DMA:
https://dlcdnets.asus.com/pub/ASUS/misc/ide/siside204a.ZIP
You may also need a USB patch:
https://dlcdnets.asus.com/pub/ASUS/misc/usb20/patch_98me.zip
Potentially there's also LAN, audio and AGP (your board doesn't have an AGP slot but probably does have integrated VGA on an internal AGP interface), but that depends on the exact board and full chipset.
