Reply 20 of 23, by zyga64
Tyrant wrote on 2021-03-10, 07:32:
Edit: I was right I just had to properly remove all the old files and it's working now. Also what version of directx are you running?
Right now I'm using DirectX 8.1 with Geforce 4MX 440 on this computer (DirectX 9 titles doesn't make much sense with such a weak components),
but you have DirectX 9 capable GPU, so try anything DX9 from this site: http://falconfly.3dfx.pl/directx.htm
If something will go wrong, you can get rid of DirectX using DirectX Eradicator. This is the soft I'm using. I also heard about DirectX Buster, but I didn't personally tested it.
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 21 of 23, by Tyrant
I've done all the above and and am running 45.23 and patchmem but Doom still runs heaps better in basic hardware acceleration. Man I'm lost. It's as though that nVidia Media Center just slows everything down.
Reply 22 of 23, by Tyrant
dionb wrote on 2021-03-10, 08:02:
You don't say exactly which board and chipset you have (961 is the southbridge, used by multiple northbridge chipsets), but thi […]
Tyrant wrote on 2021-03-10, 00:34:
Edit: All I could find was an IDE Driver and a "HFDrive" driver do you think either of those will help?
You don't say exactly which board and chipset you have (961 is the southbridge, used by multiple northbridge chipsets), but this should be the IDE driver in any event, needed for proper DMA:
https://dlcdnets.asus.com/pub/ASUS/misc/ide/siside204a.ZIP
You may also need a USB patch:
https://dlcdnets.asus.com/pub/ASUS/misc/usb20/patch_98me.zip
Potentially there's also LAN, audio and AGP (your board doesn't have an AGP slot but probably does have integrated VGA on an internal AGP interface), but that depends on the exact board and full chipset.
I did install an IDE driver. Tell me which information exactly you need to help and I'll have a look, I'm not sure where the model number would be for the board for example. I should like to update the BIOS too because I'm curious if there's extra settings in there that could help with the new card.
Reply 23 of 23, by Eep386
You can check the CPU speed using a utility like WCPUID.
