Tyrant wrote on 2021-03-11, 06:54:Can you explain that I haven't heard that term yet "bottleneck"? Also I should be able to get my hands on this […]
darry wrote on 2021-03-11, 06:52:
Tyrant wrote on 2021-03-11, 06:39:
Right thanks for clearing that up. I guess it must be the crappy GPU on my Aliexpress card causing my atrocious performance.
If that is, as I suspect, a 256MB FX5500, I doubt that the amount of video RAM would be a bottleneck (its clock speed is another question) .
https://videocardz.net/manli-geforce-fx5500-256mb-ddr
That will be plenty enough for most 98 games right?
"Bottleneck" essentially means limiting factor .
The card you linked to is AGP and, if I understand correctly you have no AGP slots on your motherboard. Did I misunderstand ?
Additionally, there is contradictory information about actually clock speeds of that model .
See https://www.gpuzoo.com/Compare/Manli_M-GF5500 … eForce_FX_5500/
Saying that an Fx 5500 is plenty for Windows 98, even if we assume the Windows 9x era ended as early as 2001 with the advent of Windows XP, is a bit optimistic, IMHO . It should work for most things, but will be significantly slower than a Geforce 3 (which was AGP only, AFAIK). See HUGE 1997*-2003 video card performance benchmark thread (Q3, Unreal, DK2, 3DM2k, 3DM2001)
Assuming the clocks and bus width of an FX 5500 are at least as good as the reference ones , see https://www.techpowerup.com/gpu-specs/geforce-fx-5500.c926 , as stated before, it should work fine .
The main problem is finding a PCI FX 5500 that has decent specs that can reliably checked before purchase .
