Reply 1300 of 1320, by villeneuve
Hi, I was about to update my DOSBox ECE installation (from the year 2019) which I never really began to use to the most current build. I had a look into the folder of my existing installation and saw the file "README for pixel-perfect patch.txt" there. That file isn't in the most current build's zip-file and indeed pixel-perfect scaling isn't mentioned anywhere even in the readme. So my question is did the pixel-perfect patch get removed in the meantime? If so, why? Is any substitute included in ECE but just not mentioned in the readme? How to get pixel perfect scaling now then?
