First post, by Almoststew1990
I am trying to revive a Dell XPS 1530 laptop. It does not power on at all. I plug in the charger and the charger's LED does not light up. Does the LED light up even if the laptop is not turned on? I.e. this would indicate a dead charger. If the LED is not meant to light up when the laptop is off, this means the charger could be fine and the laptop itself has issues.
But I don't know which it is!
Reply 1 of 2, by jtchip
The LED on the charger is almost certainly meant to be lit, even without being plugged into the laptop, at least it is on a 1998 Latitude XPi CD. I had same issue too, no LED on the charger, dremeled the charger but could see no physical damage, so ended up getting a replacement used charger, which worked.
Reply 2 of 2, by Nexxen
Use a multimeter to check if there is voltage at all from the charger.
Could be:
-faulty charger
-faulty voltage circuitry on the m/b
-a dead component on the motherboard
-faulty charger port on m/b
Check charger, inspect the motherboard.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
