First post, by tony359
Hi all
I have acquired this... D-YING (LOL!) motherboard as "faulty". When I received it it showed the usual battery leak corrosion. The BIOS VCC socket was so corroded that it had broken. I bent it a bit and the MB booted up fine. Cool!
So I washed the board as I usually do (It's a professional fluid designed for PCBs which works like a charm and removes corrosion and oxidation) and then replaced the bad sockets. As I usually do, I take all precautions such as ESD protection and rinse the board with distilled water when done. Then it dries for a day or two before I power it up again. I never had an issue to be honest.
Unfortunately, the MoBo does not boot up anymore now.
This is what I have done/noticed
- There is no BEEPS, so that tells me the CPU does not talk to the BIOS or it does not initialise somehow.
- There is no activity on Address/IO lines besides a short pulse when I power up (like a square wave?) but then nothing.
- I see the clock on the CPU but it's 50Mhz and the CPU is an AMD 386 DX 40Mhz?
- I removed the sockets and check every pin for continuity, following the traces and I did not find anything
- As far as I can see, everything is getting it's VCC
- I've checked the traces where the battery used to be and so fare they are ok
- I see a RESET pulse on the CPU happening, even though it seems to get high properly and then "slowly" going LOW.
- I've tried reading the BIOS chip with my programmer: it reads but I do not have a way to check if it's somehow corrupted?
I'll keep testing. But I was wondering if anybody on this forum has any input for me. It's a bit frustrating that the board was working and now it's not...
Thank you!
My Youtube channel: https://www.youtube.com/@tony359
Reply 1 of 17, by Nexxen
Nice board!!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 2 of 17, by theoryboy
Not very familiar with your board, but your 50Mhz comment gave me an idea, what about the osc circuit there are no jumpers present and after a cursory look
Would this be a clue ?
Reply 3 of 17, by tony359
Theoryboy
You are a star! I thought of finding the jumper setting for the board but I had forgotten. IT WORKS! Clearly the jumpers must have come off when I washed the board.
Thank you so much!! You - and this forum - are incredible!!
Reply 4 of 17, by theoryboy
Huzzah! 😀
Reply 5 of 17, by tony359
Out of curiosity, with the jumpers set to 40Mhz I read 80Mhz at the CPU. And it works. Can someone explain me how that works please? Am I not supposed to see 40Mhz at the CPU?
Reply 6 of 17, by tony359
Right, I've realised there is another (new?) fault on this board. The Keyboard doesn't work anymore, the BIOS says "Keyboard error". I cannot be sure it was working before to be honest.
I've poked the traces (the battery leaked so there is a bit of damage there) and I cannot see anything obvious. I have replaced a 10KOhm resistor which split in half while poking around but that did not resolve the issue.
I can see pulses on a pin of the keyboard connector and those pulses reach the Keyboard BIOS. The Keyboard BIOS does not seem very active to be honest. I don't seem to see much activity anywhere.
Any other great inputs on what to do next? Is there a datasheet for that chip - or does anybody have any advice on what to look for?
I did replace the Keybard BIOS' socket too but I also removed it to double check all the traces (when the board refused to boot) and everything seemed to be ok. Is the BIOS chip a standard chip I can dump with my programmer to compare with something to see if it's corrupted?
Thanks!
Tony
Reply 9 of 17, by tony359
I cannot read that chip using a 27C512 - I have tried a few different brands on the software. I get pin error. Could that be a different type of chip?
Reply 11 of 17, by tony359
Pin error.
Maybe I was not clear, apologies. I mean the Keyboard BIOS - the longer chip - which I guess it's where the keyboard is connected to? That does not have a sticker. It only says "Keyboard BIOS" on it.
Reply 13 of 17, by tony359
Ah, ok, thanks. Is there any datasheet, pinout, document available that can help me troubleshooting it?
Reply 14 of 17, by mR_Slug
Attached is the datasheet. It is a microcontroller programed as a keyboard bios. All keyboard BIOSs are compatible with the IBM AT. But most 386 onward keyboard bioses have some other functions programmed into them. So swapping the keyboard bios may not work. Some motherboards frustratingly wont boot without the keyboard bios.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 15 of 17, by tony359
thank you a lot. I will see if I have another one from another board to test but this is a good starting point!
Reply 16 of 17, by tony359
So, I found another MB with the same chip - not socketed. So I started comparing and noticed that the faulty board had the Sync missing. I looked better and... well, I guess that if I forget to solder two pins on the socket, that may not work well with the system?? 😀
Thanks for your help everybody!
Reply 17 of 17, by Nexxen
Solder on into your adventure and earn your tin badge!
