First post, by Chadti99
Chadti99
Offline
- Oldbie
How does that work?
On my current install I’ve noticed I can read a 128GB drive from within Windows 98 SE, installed on the secondary IDE port on the mobo.
Is there anyway to create a >8GB partition and install Windows 98 on it? So far when I’ve tried I’ve had the Windows 98 setup process complain about compression present or a bad sector and end the install.
I’m using an SD2IDE device if it matters.
