First post, by Intel486dx33
I pick up this IBM desktop for very little money.
It has a video memory problem.
Can we fix it ?
I will first try to re-seat the video DRAM chips and if that does not fix the problem I will try to re-float the onboard video DRAM chips.
I hope its an easy fix.
I really like the clean simple look of these IBM computers.
These are the types of IBM desktop computers we used in computer education school.
This computer sold for about $2,400 back in 1994.
This one is going to run Win95.
Anyone know where I can get the original recovery CD ?
Specs:
CPU - Pentium 90
RAM - 16mb.
Cache - 256kb.
Graphics - PCI S3 Vision 864
Audio - Crystal
Operating Systems - DOS , Win3.11, IBM OS2 v3
Reply 1 of 4, by Intel486dx33
More Photos:
Reply 3 of 4, by Intel486dx33
ArtiomWin wrote on 2021-04-07, 16:08:
Intel486dx33 wrote on 2021-04-03, 02:20:
Hello. Gladly I have one for your model (I've bought one couple of years ago). PM sent.
Thanks so much. I will try it out.
Reply 4 of 4, by Intel486dx33
Progress update:
Well it is working.
I re-seat the onboard video DRAM chips first to see if that would fix the video problem
But it did not. So the problem must be with the onboard 1mb. DRAM chips PCB surface mount solder joints.
I may work on that later but for now I just want to make sure everything else works fine. Before
I spend time soldering the motherboard. I installed a PCI video card in the mean time and it appears to be working fine.
I also had to add another IBM hard drive as the old one was pretty slow and unreliable.
I had a 1.7gb IBM hard drive in storage so I am using that and it works fine in this computer.
The bios supports it. Also the original CDROM was dead so I had to replace that too. i will try to fix later.
But the GOOD NEWS is its working.
