robertmo wrote on 2020-03-01, 10:08:
level 19 is playable in 3200x2000 😀 Allows changing game strategy 😀
Since you seem to be very interested in this game, you could check out FRABS. It is a fan made campaign with many custom levels. The levels are included with my version, but it is not set up, so I recommend you download the original version here:
http://web.archive.org/web/20010124070000/htt … cass0664/fRaBs/
You can play it in DOSBOX, or if you want to use my version all you have to do is copy-paste the following files and folders from my port to the FRABS folder:
art/icons.spe
user - the whole folder
abuse.exe
cxcore210.dll
highgui210.dll
SDL2.dll
SDL2_mixer.dll
Also in the config file "hires" and "big_font" must be set to 0. This has never been tested completely, I only played some of the first few levels.
