Ok, so I wonder if there are already clones out there:
They are:
Cardinal SoundVision (with OAK VGA onboard)
Cardinal SoundStudio (Same exact board as above, but doesn't have the VGA portion populated) - Have this one but need to replace caps - have not bee able to locate original drivers for either of these Cardinal cards
Dune recordings by alex.schroedsen
https://wiki.preterhuman.net/Cardinal_SOUNDstudio
The attachment Soundstudio1.jpg is no longer available
2TheMax SoundMedia Multimedia Board (HAs already been tested and programs that try to detect the Adlib controller chip don't detect it.  Maybe a driver issue?  I have this one, but the POT was broken when I got it. Need to replace and test.
Adlib Gold clone - 2THEMAX SoundMedia Multimedia Board?
Both cards are 12-bit PCM just like the Adlib Gold.
The attachment Cardinal_MPC500S.jpg is no longer available
The attachment 2_The_Max_Sound_Multimedia_Board.jpg is no longer available
The attachment 2_The_Max_Box_Front.jpg is no longer available
The attachment 2_The_Max_Box_Back.jpg is no longer available
