Reply 120 of 123, by fosterwj03
weedeewee wrote on 2021-04-13, 18:28:fosterwj03 wrote on 2021-04-13, 18:20:I just watched the Youtube video below about a micro-DOS build and it reminded me of this discussion. He used a processor module with a custom PCB for IO.
fyi, you mean rasteri in this thread Tiny Vortex86-based DOS gaming PC - weeCee
Yup, same one. I suspect an ATX board would be a bit less complex if you didn't bother to integrate an on-board sound solution (assuming the designer intended to use expansion boards for sound).
