486-era Gimmicks PC
First post, by furan
I'm working on an idea for a gimmick PC, basically something that has a lot of gimmicks from the 386-486 era (1989-1996 roughly, and yes, I realize that overlaps Pentium). Here are some examples of items in my collection that I'm talking about:
TechMedia speaker case
Gimmick: it sounded bad, and the magnets on the speakers were unshielded.
TEAC PA-10 personal amplifier.
Gimmick: this was for Karaoke in Japan, after the long workday. Mostly I did this because the amp in the TechMedia case sucks, but it also adds a VU meter.
Newq Gold. Stupid VFD for a drive bay. I can't use this and the TEAC PA-10 at the same time, not enough room.
Gimmick: not a real spectrum analyzer
NEC PC-FX GA A PC-FX with a 3D accelerator that hardly anybody wrote code for. A DOS/V ISA card, it and the software work fine on DOS/english Windows 3.11, aside from character set.
Gimmick: poor adoption of the PC-FX means fewer games, and barely any that support the (quite capable) 3D accelerator. Still cool.
Creative Labs 3DO Blaster Yep, that one.
Gimmick: 3DO had poor adoption, not a lot of great games.
NVIDIA NV1/Diamond Edge 3400 This can't work in the same system as a 3DO Blaster. It requires a video card with a VESA feature connector that implements pixel bus (giving the numeric values for the current pixel that are palette lookup table in the DAC, digitally, to another card, so it can decide when to do color-key overlay). But I think in a dream world, I can probably figure out a way to talk to the RAMDAC to get the pixel bus and enough signals to make it work. I might experiment with this and a different card.
Gimmick: hard to call this one a gimmick. It's really more that programming for the quadratic texturing was hard.
Gravis Ultrasound Classic
Gimmick: low amount of support, SB emulation drivers suck. Great for demoscene, though.
Miromedia Surround Dolby Pro Logic decoder
Gimmick: Not a lot of games had surround back then.
3D Blaster VLB
Gimmick: one of the first consumer 3D accelerators. Limited performance due to low amount of VRAM.
Here's a photo of this system (not yet built to specs) running both of the console cards at the same time:
Here is a video of the PA-10 in action:
https://www.youtube.com/watch?v=YFF2tDFsBLU
I want to hear about the gimmicks you remember from this era.
Reply 1 of 27, by Doornkaat
I approve! 😁👍
Especially the extra amp in the desktop case with integrated speakers. 😄
Reply 2 of 27, by imi
this is madness...
I like it ^^
Reply 3 of 27, by weedeewee
Nice.
Could use this as well... https://cdii.blogspot.com/2019/10/philips-med … ernational.html 😁
Do not ask Why !
Reply 6 of 27, by furan
vetz wrote on 2021-04-16, 21:42:
So what is the full spec of this build?
Another gimmick (if room) would be to put in a ReelMagic card for some MPEG decoding with the few games supporting it.
It doesn't have a full spec - that's why I made this thread. I'm planning to swap the ISA backplane + Intel 486 DX4-100 WB on a half-size PICMG card it has, for a PVI-486SP3. I will probably use an IBM Blue Lightning DX2/66 for kicks.
I'd still like to find an i2m PCI CD-I playback card, as rare as they are. I have the RealMagic card + games, but only 4 ISA/VLB slots with the PVI-486SP3, all reserved for cards so far.
Reply 7 of 27, by cyclone3d
The PC-FXGA card was meant to be used to play NEC PC-FX console games on a computer.
https://en.wikipedia.org/wiki/List_of_PC-FX_games
LGR review.
https://youtu.be/JM04vH2et5A
Only 62 official games released for that console, but it kinda came at a bad time because the Playstation and Saturn were released just a bit before the PC-FX.
It was also only released in Japan.
So not really a gimmick... just not something that most people would have had a use for.
It is basically the PC-FX console on an ISA card. It just uses the PC for the CD drive and for the save game files.
So if you already had a PC, you could save a bit of money by getting the PC-FXGA ISA card or the PC-FX PC98 card.
And to top it off, you have to hook up a separate display (composite or S-Video) to use it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 27, by cyclone3d
Oh.. as far as backplanes setups go.... If you are going for a 486 setup, you can get a PCI/ISA SBC and a PCI/ISA backplane. That can give you up to 4 PCI and a bunch of ISA, you just have to have a backplane that will also work with your specific 486 SBC due to fun with PCI addressing or else you may end up with only 1-2 PCI slots actually working. I found that out the hard way so I have a few extra PCI/ISA backplanes.
And I am pretty sure that I will still only have a max of 3 PCI slots available due to the onboard video being PCI.
That system is in limbo because I haven't had time to mess with it in quite a while.
YMF7x4 Guide
Reply 9 of 27, by furan
I’m confused as to why you’re explaining what the PC-FX console is - I’ve had the PC-FX GA in this system for years. 😀 The console was a flop, and the card is a gimmick. The bottom photo has it hooked up to a composite monitor. Did you skip reading the post maybe?
It currently has an ISA backplane, but I can’t use a PICMG backplane, as I need VLB for the 3D Blaster VLB.
Reply 10 of 27, by Hezus
This thing is ridiculous. I want one.
Visit my YT Channel!
Reply 11 of 27, by Doornkaat
Too bad the case only has two 5.25 inch drive bays. A CD changer would be a nice gimmick as well, especially on a desktop case where the drive is always easily accessible.😄
Reply 12 of 27, by mpe
Nice one. Might make more sense to go for Gravis Ultrasound ACE rather than Classic as the latter is a resource hog (considering a number of periherals you want to use in your system).
Blog|NexGen 586|S4
Reply 14 of 27, by The Serpent Rider
Not to mention, that some of them were quite spicy.
Reply 15 of 27, by waterbeesje
As there won't be much front space left, there's another option. Install any SCSI card with external header and get a CD-ROM tower. Ludicrous but cool in its own way.
Stuck at 10MHz...
Reply 16 of 27, by furan
weedeewee wrote on 2021-04-17, 10:17:
While you're at it... throw in a pcmcia/cardbus adapter 😀
PCMCIA is near-ISA and CardBus is near PCI, not sure where the gimmick part would come in. I use a CardBus to PCI bridge from laptops to add extension cards (have added a 3dfx this way).
Reply 17 of 27, by furan
waterbeesje wrote on 2021-04-17, 17:15:
I have to use a panasonic/matsushita drive with the 3DO Blaster. I have tested, and so far it works with any drive I've tried that uses that interface, but that can't be external over something like SCSI.
Reply 18 of 27, by weedeewee
furan wrote on 2021-04-17, 17:15:
ok ok ... it's clear you just have to add a fufme.
Do not ask Why !
Reply 19 of 27, by cyclone3d
furan wrote on 2021-04-17, 07:42:
It was more for people who didn't know what it was.
I still have my TG16 with CD expansion and around 100 games. Kinda one of my favorite consoles.
YMF7x4 Guide
