First post, by TheMechanist
creating images, mounting them and file sharing can be annoying, especially with MSDOS as guest OS without network sharing, so I coded this little tool to map a host directory to a raw hdd image, which could be refreshed from inside the guest, so cross development and testing is possible like with DOSBox ... this was discussed earlier here (XTulator (yet another PC emulator)), the tool is just a proof of concept ...
swap42 mapper tool
Greetz
Asato
Nec Powermate 80286, 12 Mhz, 1 MB RAM, onboard Paradise VGA, 130 MB ST3144AT, ES1868 ISA soundcard, MS Dos 3.31
Unchained demo group
swap42
Reply 1 of 3, by mr.cat
Thanks, that looks promising. I've seen 9p recommended for Linux guest/Linux host stuff, but nothing much for DOS.
Reply 2 of 3, by TheMechanist
Good news! Tested it with Windows 98. If you change the properties of the drive, which is associated with the swap42 image, to "removable" (hardware manager) Windows detects filesystem changes by itself so it's possible to do a rescan even for Windows 98 as guest OS (if windows monitors it by volume serial I'll have to change the function, because it now sets a human readable volume serial (DDMM-HHMM) and not the fat16/msdos way of calculation so the serial only changes after minutes).
Unfortunately the swap42 rescan.com for MSDOS doesn't work (windows detects that it wants to low level access disk) ... but it's possible to access disk sectors under windows (found some example codes) .. since I have no clue about win32 programming somebody else has to write a tool for Windows ..
I'll add a possibility to perform a rescan from swap42 host application ...
swap42
Reply 3 of 3, by TheMechanist
Although the tool was developed on and for Linux and it uses a lot of "non portable linux functions" like mmap, fallocate or fstatfs, so compiling with cygwin/mingw isn't unfortunately an option, the tool runs flawlessly with WSL (Windows subsystem for Linux, tested with debian, but should work with all WSL-distributions), so creating images from host directories is possible on Windows 10 too!
The only drawback is, that windows locks the image file, so it can't be refreshed by host/guest like it's possible on linux.
swap42
