First post, by Intel486dx33
How can one get a standard 486 ( 168-pin CPU ) to work in a 169-pin Intel overdrive socket ?
Reply 2 of 5, by mpe
UP# pin on the 486SX CPU needs to be connected to ground. Sometimes there is a jumper on the board for that.
Blog|NexGen 586|S4
Reply 3 of 5, by pentiumspeed
Pull the socket pin B14 low via ground this connects to the UP# pin on the 486SX.
Then you can use normal 486DX or DX2 CPU without need to buy a overdrive 487 which is expensive.
Cheers,
Great Northern aka Canada.
Reply 4 of 5, by Intel486dx33
pentiumspeed wrote on 2021-04-30, 14:34:
Cheers,
Do you mean to pull out of socket B14 ?
Reply 5 of 5, by evasive
Pull low means make the signal low ( = logical zero) by connecting it to ground.
