First post, by gabimor
How are you, mates?
I bought a second Pentium 3 1,4 Tualatin, cause the other one I have can die. ...
The one I received today is a Compaq Spare part, with an attached heatsink.
Pentium 3 Tualatin doesn't have the die exposed, so the risk to remove the heatsink is not high, I think....
Have you ever did this?
Heat is my friend in this case, I know, but I want to ask for someone who already did it.
Thank you.
Have a good weekend!
Reply 1 of 4, by gabimor
Guys, I did it.
It was so easy.
While working, The Pentium generated heat, and the heatsink became "loose", instead of how it was in my hands.
Then I used a hair dryer.
I'll post the pictures later.
Reply 3 of 4, by Thermalwrong
Thanks for the pictures! I recently bought the same Compaq 1.4GHz for my Tualatin setup but could not get the heatsink to come off, good to know that it might move with some heat 😀
I was stuck using the heatsink it came with, which might work, but it's pretty basic and hard to mount a fan to.
Reply 4 of 4, by shamino
Meanwhile, on the other side of the world...
I permanently epoxied a heatsink to a Tualatin 1.4GHz so that I could use it in a Compaq.
