First post, by almeath
I have a question about the correct aspect ratio setting to use for the original DOS version of SimCity running in DOSBox.
I thought that using "aspect=true" provides the most authentic experience, given that it attempts to scale the screen to the 4:3 ratio of old CRT monitors. I use this for almost all my DOS games.
There are a select few games, of which SimCity is one, where this seems to fail. Based on the attached screenshots, selecting "aspect=true" appears to squash the screen vertically, making all the squares look like rectangles.
I am wondering why this is so, and is there a way to obtain a proper 4:3 ratio for this game (and others) while avoiding distortion in the image?
    57.98 KiB
    413.53 KiB
    382.57 KiB
    66.5 KiB
DOSBox SVN for macOS (x86-64) - customized with Munt MT-32, Nuked OPL3, 3dfx Voodoo, Extra RAM, Large HD, and more.
https://github.com/almeath/DOSBox-SVN-64-bit-for-macOS
Reply 1 of 9, by megatron-uk
There are so many variations of Dos Simcity that it's hard to know for sure, but is that not the EGA high resolution mode of 640x350? If so, that's going to be a narrower picture than either 320x200/320x240 or 640x400/640x480.
https://www.target-earth.net
Reply 2 of 9, by almeath
Yes, it is the EGA high resolution mode. That must be it then.. the non-standard resolution does not work properly with the aspect ratio correction, which is designed for the standard 640x and 320x resolutions? I expect there is no way to get around that then, apart from playing it in the lower resolution mode. Or leaving aspect ratio correction off and playing in widescreen mode, which while less accurate is at least more pleasing to the eye.
Reply 3 of 9, by MrFlibble
A while ago there was an in-depth topic about the various resolutions and what they looked like on real 4:3 CRTs. Here it is:
The Quest for Pixel Perfect DOS Emulation
I won't pretend that I understand the reasons why some video modes would stretch to cover the whole screen while others won't, but one of the examples was the main menu screen from Lemmings which is 640x350, and the topic author showed that it was centred on the 4:3 screen and not stretched with a real DOS CRT display:
https://imgur.com/UNIzK8O
I have not the slightest idea if this applies to all games that run in this resolution, but since applying aspect correction to SimCity results in obvious vertical stretching, maybe this was the case as well? That, or the DOS version devs just didn't care.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 4 of 9, by mothergoose729
DOSBox doesn't emulate the display timings in much detail. I know with lemmings and some other games that have a resolution of 640x350, that a more accurate framing is to center it vertically in a 640x400 resolution. On a real VGA this is done through display timings by manipulating the active pixels and the front/back porch.
DOSBox-X, PCem and some other PC emulators do attempt to emulate the display more accurately and they might give you a better result with the right settings. In DOSbox, you would set the scaler to "normal2x" and then force the resolution to 640x400 to achieve the effect - or dial in a custom resolution for DOSBox to use if you have a CRT monitor or an LCD that is accommodating.
Reply 6 of 9, by ripsaw8080
Rank DOSBox Author
DOSBox Author
To be more specific, there is a known issue with the aspect correction of 350-line modes when using the machine=ega setting, which includes text modes due to the 14-line font. However, I'm not aware of any compelling reason to use the EGA machine type for original SimCity.
The attached screenshots in the first comment of this thread seem to show the aspect correction working as intended. There are countless posts on this forum questioning the results of aspect correction because the graphic elements of certain games do not appear to be square or round as expected. It's usually because the graphics elements were designed with a square-pixel mode rather than the non-square-pixel mode the game uses. Dungeon Keeper is a classic example, with its image of a CD shown while the game is busy loading data and its radar display in the upper left of the screen -- seems like they ought to be circles, and they are when aspect is not corrected, but they become ovals when aspect is corrected.
Reply 7 of 9, by almeath
ripsaw8080 wrote on 2021-05-27, 20:40:
OK, however just for the record, my machine type is set to svga_s3. I had selected the high resolution EGA mode from within the SimCity installation settings.
Reply 8 of 9, by ripsaw8080
Rank DOSBox Author
DOSBox Author
almeath wrote on 2021-05-28, 03:50:
I guessed that was the case because your screenshots with aspect=true already have the "proper 4:3 ratio" you asked for, so I'm trying to explain that for the purpose of aspect correction the aspect ratio refers to the display area and not what game developers choose to depict within the display area. 😉
Reply 9 of 9, by almeath
ripsaw8080 wrote on 2021-05-28, 04:36:
That makes sense, thanks. In SimCity, I like the 16 color EGA mode because I find the 256 color VGA at 320x200 too chunky and low res for my tastes. I am quite happy to play this game in a stretched wide screen format to get proper proportions in the graphics.
