debs3759 wrote on 2021-03-22, 16:54:I just found a web site that legally shares the source code and lots of apps and documentation for CP/M, including stuff the pre […]
I just found a web site that legally shares the source code and lots of apps and documentation for CP/M, including stuff the predates Digital Research. I'll be making good use of it (mostly the x86 ports, but to a lesser extent also the Z80 code and apps). Thought some of you might find it useful.
The sources are at
http://www.cpm.z80.de/source.html
The root (http://www.cpm.z80.de/index.html) includes internal links to Tim Olmstead Memorial Library (DRI Manuals) , DR binaries, and a lot of other resources.
Thank you very much for your thread! 😎
I really appreciate it - I browsed that site along time ago, thanks for the flashback..
gerry wrote on 2021-03-23, 10:47:
how tiny source code used to be, even for entire operating systems. I took a look at the 1976 'basic-e' code, just a perusal - very interesting
Yup. That reminds me of my father's old Popular Electronics magazines from the late 1970s.
At the time, they covered the basics of good old Control/Program Monitor.
That's how it was being called before it became popular.
Anyway, most people likely continue calling it by its commercial name,
Control Program for Microcomputers, which gives me a teary eye sometimes. 😢
Because, the term "monitor" (monitor program) is almost forgotten nowadays.
A monitor program is a miniature OS, even simpler than a BIOS. It contains a minimal command prompt, like that of BASIC interpreters.
Sometimes, it has a little hex editor or debugger built-in. The term "monitor" was used in Sharp's line of 8-Bit computers (Sharp MZ series)., for example.
And the original Tron movie. There's also a program that's being referred to as "monitor" by the Master Control Program (MCP.. CPM.. Hm..).
Apropos, BIOS.. In latin, it also means 'life'. The BIOS of CP/M-80 was the low-level part, which later on also inspired the IBM PC's firmware, the PC-BIOS.
The PC-BIOS literally gave life to the machine. 😄
Edit: Minor edit.
