First post, by Pierre32
The mobo: http://www.win3x.org/uh19/motherboard/show/3282
I have a COAST module of unknown spec which I'd like to use in this mobo if possible.
The attachment coast module.jpg is no longer available
(They aren't broken traces on the left; just some gunk before it was cleaned properly.)
From the manual:
The attachment manual.png is no longer available
I've tried all combinations of JP1, 2, 7 & 8 to no effect.
The attachment settings.png is no longer available
Questions:
- What is Bank 0 at bottom left of the motherboard image? L3?
- How does that interact with a stick in SL1?
- Any other clues that could help me out, or just rule out using this module?
Reply 1 of 2, by BitWrangler
If I was gonna guess which board that module went in, I'd go with a 430FX, don't know how to describe the difference, but the FX ones look more like ISA I/O card chip packaging and PCB construction and the VX and TX ones look more like good PCI graphics card type packaging and construction.
Reply 2 of 2, by Pierre32
I'm smelling what you're stepping in, if you know what I mean. Lo and behold, the module was originally plugged into an FX board: http://www.win3x.org/uh19/motherboard/show/5956
