First post, by MoG91
Evening All,
I have a Slot 1 asus board that I want to use as a test bench for older parts that I want to sell. Most of my slot 1 processors are P3s however not P2s. I’d like to use a 600mhz P3 SL3JM which has a 100mhz bus speed. Which I believe is the maximum supported by this board. The manual only lists P2s but I know that P3s often work in slot 1 boards even if they aren’t listed. Would this configuration work? Let me know if anyone has experience with this. and thanks in advance,
