How can i launch games from Dosbox 0.65?
First post, by InPhets
Hi, im new here and with Dosbox.
So the question is really simple.
How do I launch a game from dosbox? Example Settlers2 gold.
Take all from the beginning when u explain.
Tnx 😀
Reply 1 of 26, by eL_PuSHeR
Welcome to the forums.
Read the FAQ/Guidelines located at the appropiate section(s) in the forum.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 26, by InPhets
Yes, but didnt understand it. I would be glad if someone explained to me, in a easy way 😀
Reply 3 of 26, by wd
Rank DOSBox Author
DOSBox Author
Well those are the easy explanations, you don't want to read the others 😉
Basically they guide you step by step, if you don't understand some step
feel free to ask, same if some step simply doesn't work for you.
Reply 4 of 26, by InPhets
Okeii, it stands i shall mount it from a CD, but i dont use a CD.
But i did mount it from the directory at my HD, so now, how do i load it, so the game runs?
Reply 5 of 26, by wd
Rank DOSBox Author
DOSBox Author
Well depends, where's the game (full path), how did you mount it?
Reply 6 of 26, by InPhets
Z:>mount C "C:\DOSBox stuff\MyGame" Thats the mount command i used..
But MY full path is D:\Spill\Settlers2\Settlers2gold\
S2.exe
So i did write Mount D D:\Spill\Settlers2\Settlers2gold\..
Reply 7 of 26, by InPhets
Heelp me someone, plz 😀
Reply 8 of 26, by wd
Rank DOSBox Author
DOSBox Author
What's the response when you type
Reply 9 of 26, by InPhets
"Drive D is local directory D:\Spill\Settlers2\Settlers2gold"
Thats the message i got..
Reply 10 of 26, by wd
Rank DOSBox Author
DOSBox Author
Ok, that's fine so far.
Do you remember dos commands? Type "D:" to change to the
d drive (which you just mounted), then type "dir" to see what
files are there. Those should match what is in your
directory.
Reply 11 of 26, by InPhets
Yes, good. I got up a list for that folder, all the files.
And what now? 😀
Reply 12 of 26, by eL_PuSHeR
You need some crash course in ms-dos commands mate.
type d: to change to d drive
then type in the command used for starting the game (bat, com, exe are all executable extensions).
E.G. s2.exe or play.bat
Intel i7 5960X
8 GB DDR4 (2100)
Reply 13 of 26, by InPhets
Yes, i wrote D:, and ..
D:\>S2.exe, but nothing did happand...
Reply 14 of 26, by wd
Rank DOSBox Author
DOSBox Author
So is s2.exe really there? (look at the output of dir)
What means "nothing happened", no message or something?
Try install or setup as well.
Reply 15 of 26, by InPhets
Ok ok. yes nothing did happand, no messasge or nothing, just a "clear" line between the lines..
Reply 16 of 26, by wd
Rank DOSBox Author
DOSBox Author
install/setup?
Reply 17 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
what is the size of s2.exe ?
I thought you started settlers2 usign a different executable though
Water flows down the stream
Reply 18 of 26, by InPhets
Hmm s2edit.exe is working.. The map creator thing..
hmm but fuck(sry the language), why is s2.exe 0 byte?
Does i smell reinstall?
Reply 19 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
sounds like a corrupted executable and a reinstall is a good idea
