IBM APTIVA 2144-M63 BUILD - BIG UPGRADES
Reply 100 of 140, by chrismeyer6
Very nice. Definitely want some pictures of it on the card.
Reply 103 of 140, by chrismeyer6
That card looks fantastic with that water block on it. I really love the look of EK parts. Probably overkill and would be considered a waste of money but I really want to water cool my C2D E8600 Nforce 680i system just cause I think it'll be a fun project
Reply 104 of 140, by KSHIRZA1
chrismeyer6 wrote on 2021-06-14, 15:04:
It’s 100% for the hobby and totally worth it in that respect. It’s nice to look at and very reliable. Can’t wait to see it!
\\IBM Aptiva 2144 build\
My instagram @kshirza1
Reply 105 of 140, by chrismeyer6
I'm in the planning phase now hopefully it'll be a fall project. What's really surprising is that water blocks for the 775 socket are still available everywhere and even blocks for the 680i motherboards are still super easy to find and quite inexpensive as well
Reply 106 of 140, by KSHIRZA1
chrismeyer6 wrote on 2021-06-14, 20:00:
It’s going to be really sweet! I switched back to soft tubing, Using 1/2in 3/4od. No rush, mine has been evolving for years and not expensive at all.
Reply 107 of 140, by chrismeyer6
I know I can't wait and it'll be a soft line build
Reply 110 of 140, by chrismeyer6
That's beautiful looking
Reply 112 of 140, by chrismeyer6
Wow! That's a thing of beauty right there seriously beautiful work my friend.
Reply 113 of 140, by chinny22
My brain hurts!
1 second I'm reading about graphics cards with more ram then my daily driver, next a 32MB stick of EDO!
Seriously though 2 very nice builds.
Reply 115 of 140, by Señor Ventura
My aptiva doesn't let me upgrade teh cpu until 200mhz MMX, only at 200mhz, without MMX.
I imagine it depends of the number of the build, right?, Where must i search to find the build of mine pc?.
Reply 116 of 140, by Limpem
Señor Ventura wrote on 2021-07-12, 19:46:
Depends on the Motherboard inside your aptiva (I upgraded mine to a 93H7122).
Some motherboards can be upgraded to a 200 Mhz mmx if you also swap the voltage regulator to a different one (233 Mhz will work on those boards as well, but will generate bios errors every boot unless it is explicitly supported by the board).
If you cannot swap the voltage regulator, a pentium MMX overdrive might be an option.
I also read some people running a mmx without swapping the voltage regulator, but you will be overvolting the mmx by quite a large amount which will generate a lot of heat and can significally decrease the lifetime of the cpu.
430HX/P1 233MMX/64MB/S3VirgeDX,Voodoo1SLI(King Shaman)/AWE32
440BX/CelTualatin1400/512MB/Banshee, PowerVR PCX2/AWE64Gold
645DX/P4Northwood 3,5Ghz(Oc)/512MB/Voodoo5500/Vortex2
875P/P4EE 3,4Ghz/1GB/GeforceFX5950/Audigy2ZS
Z97/i3-4370/16GB/GeforceGTX960/X-Fi
Reply 117 of 140, by KSHIRZA1
This is the reason I went with the overdrive cpu. 200 mmx no problem and easy install without fiddling around. Switch to 66.6 fsb via jumpers.
This was my info source and it lists machine types:
http://aptivasupport.com/uas/cpu/
Reply 118 of 140, by Señor Ventura
KSHIRZA1 wrote on 2021-07-13, 10:15:
This is the reason I went with the overdrive cpu. 200 mmx no problem and easy install without fiddling around. Switch 66.6 fsb v […]
This is the reason I went with the overdrive cpu. 200 mmx no problem and easy install without fiddling around. Switch 66.6 fsb via jumpers.
Ah, yeah, i alreadyremember where the problem was: my motherboard doesn't have the jumper to modify the voltage.
By the way, What solution did you choose for the heatsink?, i'm thinking about an 8x8x5cm copper one, but i can't find one... ^^u
Reply 119 of 140, by KSHIRZA1
Señor Ventura wrote on 2021-07-13, 19:14:
The overdrive cpu come with a built in heatsink.
Re: IBM APTIVA 2144-M63 BUILD - BIG UPGRADES
