Reply 39480 of 54980, by dionb
Via So370 chipsets support the ISA bus, so it could work. You might need some extra passive bits and pieces (SMD resistors & caps) here and there though. Best bet would be to find a pic of a version of the board with slot present and compare all the stuff around it with yours.
Here's a half-decent one of the MS-6309: https://images.anandtech.com/old/motherboards … 33a/msi6309.jpg
That GA-7N400L is an absolutely great board, probably my favorite SoA board. It's not that it has a ton of features, it just has the basic nForce2Ultra-400 chipset, but that means excellent performance. Anything else you can add in a PCI slot. The only onboard stuff is mediocre audio and nework, but you can disable both. There were more extensive versions with extra PATA RAID, SATA and IEEE1394 chips onboard, but none beat the better PCI options.
Also: nice Speccy games. Gauntlet brings back memories...
Reply 39481 of 54980, by iVirtualZero
dionb wrote on 2021-06-13, 23:11:
Via So370 chipsets support the ISA bus, so it could work. You might need some extra passive bits and pieces (SMD resistors & cap […]
Thanks for the great reply, would love to own a ZX Spectrum someday or a Commodore. As for the Socket 370 motherboard, it does indeed look like a decent board. Would be better with an ISA port. Is there any schematic or guide out there to know what those missing components are?
Reply 39482 of 54980, by dionb
iVirtualZero wrote on 2021-06-13, 23:48:
Depends on the specific board. I'm not aware of any documentation, hence the suggestion to use pictures.
Reply 39483 of 54980, by megatron-uk
Picked up an ESS 1868F to go in an Olivetti PCS 11 (single ISA slot!) which someone has put aside for me.
Always used a real Soundblaster in all of my PC's (well, apart from those that were dual Soundblaster/GUS machines), so it will be interesting to see what this is like.
https://www.target-earth.net
Reply 39484 of 54980, by chinny22
Just make sure the Dell PSU isn't the non standard ATX one, I think your ok looking at the cables but doesn't hurt to do a double check against its part number.
For that price though it's hard to complain!
Reply 39485 of 54980, by Nick4
Got this new-in-box case recently:
Really heavy, made of thick metal. Unfortunately, the PSU is missing. Will fit some WinXP build, I guess.
Reply 39486 of 54980, by buckeye
Nick4 wrote on 2021-06-14, 12:44:
Got this new-in-box case recently: https://i.imgur.com/qsWlAhcl.jpg Really heavy, made of thick metal. Unfortunately, the PSU is […]
What a nice looking case, I want one!
Reply 39488 of 54980, by iVirtualZero
chinny22 wrote on 2021-06-14, 08:43:
I will not be using the Dell psu. Going to sell it on.
Reply 39489 of 54980, by Miphee
I love strange looking rams, probably from a Sun SPARCstation.
Reply 39490 of 54980, by Horun
Nice finds!
Reply 39491 of 54980, by pentiumspeed
Just got package from Rome, Italy today. Took less time than expected.
In it is Compaq Deskpro M 486SX 25 with other goodies, most sought after is power supply board.
How long I wait for any possible insects to die?
Cheers,
Great Northern aka Canada.
Reply 39492 of 54980, by bjwil1991
Bought a DX4/5x86 interposer and a NanTan FMA7600 laptop.
Sellers' photos:
The attachment s-l1600.jpg is no longer available
The attachment s-l1600 (1).jpg is no longer available
The attachment s-l1600 (2).jpg is no longer available
The attachment s-l1600 (3).jpg is no longer available
Unfortunately, the laptop hasn't the charger and I found the schematic/pinout for the charger/DC port so I can daisy chain my own PSU brick.
Reply 39493 of 54980, by pampilhoso
Managed to get a PODP5V83 for 50 bucks.
The attachment IMG-20210616-WA0003.jpeg is no longer available
Reply 39494 of 54980, by chrismeyer6
Wow!! That's a hell of a good deal nice find!
Reply 39495 of 54980, by luckybob
Agreed! I gotta hand it to you, $50 is a good deal if it works.
(Golly, this 'hobby' has gotten expensive in the last few years, eh?)
Reply 39496 of 54980, by subnet_zero
I got a nice deal on a ASUS P4P800 SE with socket 478 and an Geforce 6800GT APG with 256MB DDR3 with the mermaid artwork from the NVIDIA Nalu Tech-Demo.
Also included 1x 512MB DDR400 RAM from MTD that was "Made in Germany", a Northwood 3GHz Pentium 4 (sadly with 2 missing pins, see picture) and a beefy CPU cooler with adjustable fan, the I/O shield, a IDE and a Floppy cable.
This was 46€ with shipping, i guess it's a good deal these days on ebay.
The P4 CPU might work despite those two missing pins. The seller shows a picture from the initial boot screen of the board. I will find out in the future.
Reply 39497 of 54980, by aitotat
I just got something that you just can't let pass:
uc?export=download&id=18sy_L17ciJlllOgTVX1IdW5-nGI_U9hg
Reply 39498 of 54980, by cyclone3d
aitotat wrote on 2021-06-16, 16:56:
I just got something that you just can't let pass: https://drive.google.com/uc?export=download&id=18sy_L17ciJlllOgTVX1IdW5-nGI_U […]
Computer with a Roland LAPC-I. Very nice!
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 39499 of 54980, by A001
Who'd be able to ID this behemoth on the left?
