First post, by AndyGoodwin
When i play doom on the laptop the audio cuts out after the floppy logo loads on the bottom right corner of the screen. Could running windows 98 off a usb be a problem or could it be something else?
Reply 1 of 1, by BitWrangler
Well I'd check in device mangler to see if any hint of USBness is sharing IRQs with any hint of Audioness and make it not so.
