First post, by GasparB123
Hello, I have a retro computer that I use to run some old windows 98/XP software. It originally came with an AMD Duron 800, but I bought and upgraded it to a Sempron 2300+. All is well, at startup it recognizes the new processor. The problem is when I install 98SE or XP, the computer believes it is an Athlon MP running at 950 mhz. I downloaded and installed Everest and it confirms my suspitions. With that config, it is still an upgrade over the original, but not the double operating frecuency I was expecting. I was wondering why this was happening and if it could be fixed in some way. Here is the Everest summary, so you can see the motherboard model and maybe other important information (sorry for the spanish, I hope you can understand it):
Edit: I found that the old CPU used to read AMD Pro 2200+ in BIOS, and now it reads Pro 2000a+. I know it's a nonsense name given by PC manufacturers to make you think you were buying something awesome, but it still does not change the fact that windows does not recognize it correctly. I've checked the AMD number stickers on the processor and thats how I know their real names and specifications.
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Versión EVEREST v2.20.405/es
Sitio Web http://www.lavalys.com/
Tipo de informe Asistente de informes
Ordenador GASPAR-PC
Generador Gaspar Bosch
Sistema operativo Microsoft Windows 98 SE 4.10.2222A (Win98 SE)
Fecha 2021-06-26
Hora 01:06
--------[ Resumen ]-----------------------------------------------------------------------------------------------------
Ordenador:
Service Pack del Sistema Operativo -
DirectX 4.06.03.0518 (DirectX 6.1a)
Nombre del sistema GASPAR-PC
Nombre de usuario Gaspar Bosch
Placa base:
Tipo de procesador AMD Athlon MP, 950 MHz (9.5 x 100)
Nombre de la Placa Base PCChips M825G (2 PCI, 1 AGP, 1 CNR, 2 DDR DIMM, Audio, Video, LAN)
Chipset de la Placa Base VIA UniChrome KM266 Pro
Memoria del Sistema 1024 MB (PC3200 DDR SDRAM)
Tipo de BIOS AMI (02/14/05)
Monitor:
Tarjeta gráfica NVIDIA GeForce 6200
Acelerador 3D nVIDIA GeForce 6200 AGP
Monitor LG IPS WSXGA [NoDB] (709NTNH97503)
Multimedia:
Tarjeta de sonido VIA AC'97 Enhanced Audio Controller
Almacenamiento:
Controlador IDE Primary IDE controller (dual fifo)
Controlador IDE Secondary IDE controller (dual fifo)
Controlador IDE VIA Bus Master PCI IDE Controller
Disquetera de 3 1/2 GENERIC NEC FLOPPY DISK
Disco duro GENERIC IDE DISK TYPE47
Disco duro SanDisk
Lector óptico TSSTcorp CD/DVDW SH-S182D
Estado de los discos duros SMART Desconocido
Particiones:
C: (FAT32) 57225 MB (49233 MB libre)
Dispositivos de entrada:
Teclado Standard 101/102-Key or Microsoft Natural Keyboard
Ratón PS/2 Compatible Mouse Port
Red:
Tarjeta de Red PPP Adapter.
Tarjeta de Red VIA Rhine II Fast Ethernet Adapter (169.254.200.118)
Dispositivos:
Controlador USB1 VIA VT83C572 PCI-USB Controller
Controlador USB2 VIA USB 2.0 Enhanced Host Controller
Dispositivos USB USB Mass Storage Device
Reply 1 of 8, by Falcosoft
GasparB123 wrote on 2021-06-26, 04:11:
Your problem has nothing to do with what your OS or computer believes. From the report it can be clearly seen that your CPU really runs at 950 Mhz (that is 9.5 * 100). By specification your CPU should run at 1583 Mhz (9.5 *166Mhz). As you can see your problem is the 100 Mhz bus frequency (instead of 166 Mhz), the 9.5x CPU multiplier is recognized properly. Your motherboard most likely does not support 166 MHz FSB but you can try to set it in the BIOS manually to 133MHz. This way you will get ~1266 Mhz (9.5 * 133).
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 8, by darry
Assuming you have revision 9.2 of the board, here is the manual .
Setting bus clock requires changing jumpers (see page 29 of pdf) .
The attachment 825G_v9.2B.pdf is no longer available
Here is what is likely the latest BIOS ( apparently for revision 9.2A of the board according to https://web.archive.org/web/20060319060248/ht … nuID=35&LanID=0 ):
The attachment 050516S.zip is no longer available
Some drivers to be found here (if you avoid the ads and downloader apps and just download what you want/need) :
https://members.driverguide.com/driver_search … ?ref=h2&q=m825g
Personally, I would use reference drivers from the chipset manufacturer .
Reply 3 of 8, by GasparB123
Falcosoft wrote on 2021-06-26, 05:53:
Thanks a lot for this, thanks for the info. I had not realized that the base frequency was modified via hardware. Thanks to the manual passed on by darry, I found the corresponding jumper on the motherboard and it supports 166 mhz. So I will try this. Thanks again.
Reply 4 of 8, by GasparB123
darry wrote on 2021-06-26, 06:07:
Assuming you have revision 9.2 of the board, here is the manual . […]
825G_v9.2B.pdf
050516S.zip
This is awesome, thanks a lot. I was looking for that bios for agess. I tried navigating the web archive for it but the intermediate pages were down at the moment. I'll try this and get back to you.
Reply 5 of 8, by GasparB123
Welp, the jumpers are there, but it's directly wired. Don't know what to do now, I'm not really a soldering expert.
Reply 6 of 8, by GasparB123
GasparB123 wrote on 2021-06-26, 15:29:
Here is an image of how the jumpers look (JP3 and Jp4)
The attachment WhatsApp Image 2021-06-26 at 6.07.12 PM.jpeg is no longer available
Reply 7 of 8, by darry
GasparB123 wrote on 2021-06-26, 21:13:
That does complicate things . There may be a reason, other than cost-cutting, for that being permanently hardwired . Maybe this board revision is not stable at higher clocks . There may also be components missing for higher clocks to work . Either way, if you want to try it without soldering in a jumper block yourself, your best bet is finding a local TV repair shop place that could probably do it for you for a small fee .
That being said, it may be simpler to get a better motherboard .
Reply 8 of 8, by GasparB123
darry wrote on 2021-06-26, 21:29:
Yes, you may be right about getting a better motherboard. I'm from Argentina and I can't find anymore Socket 462 boards in my local area, and bringing it in from the capital is kind of expensive. I mean, if they could install the jumper male pin header, I could just use a pair of female jumpers, try the different frequencies, and see what sticks.
It seems weird that it would be unstable or missing components, if the manual you passed on to me says it can be changed 🤣, but oh well, I'll give it a shot.
