First post, by StaffelGuard1917
Helo, people ! Contiuning my eiger saga... I managed to detect ESS1688 under dos - booting from win95 command prompt - but now there are IRQ conflicts, sound card utility refuses to detect any available irq's - so maybe if I make free irq 7 it will run on it, but irq 7 is set for lpt port... how can I free it ? the machine is Compaq Contura 430cx notebok...
Reply 1 of 8, by DoutorHouse
StaffelGuard1917 wrote on 2021-06-29, 10:52:
Can you disable IRQ7 for the LPT port on BIOS?
Reply 2 of 8, by zyga64
If there is no such option in BIOS, or you can't access BIOS setup easily, I would try CMOSer from here https://www.sac.sk/files.php?d=16&p=16
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 4 of 8, by Jo22
If two devices use the same IRQ, there's no IRQ conflict unless you're using both devices simultanously or are running a multi-tuser/multi-tasking OS..
Like OS/2 or Windows 9x, maybe. DOS alone should be safe.
Anyway, disabling an IRQ on an ISA LPT card is simple. On the card, just cut the IRQ line in question.
DOS and Windows 3.x don't use IRQ signals for printer communication. OS/2 does, however.
Edit: Just realized you're using a laptop. 😅
Reply 6 of 8, by mothergoose729
I don't know what board you have, but any typical award bios will have the option to reserve IRQs for legacy ISA. I use an LPT sound card and that is part of how I manage. For my system IRQ conflicts with LPT absolutely has an effect on some games but not most of them, so I typically run my sound card on IRQ 5 and my LPT on IRQ 7. You could easily reverse them too if that is easier for you.
Reply 7 of 8, by StaffelGuard1917
kixs wrote on 2021-06-29, 13:24:
Do you have correct drivers? IRQ 5 seems free and it can't use it.
I have CD with original drivers from EIger soundcard..
Reply 8 of 8, by StaffelGuard1917
mothergoose729 wrote on 2021-06-29, 15:26:
IT's a Compaq Contura 430CX and Compaq LTE/ELite 75CX notebooks I'm trying to run this card with... both are 486DX4 with ms-dos 6.22 and in 95osr2
