Reverb on Audigy 2 ZS
First post, by someperson42
I have an Audigy 2 ZS that has some odd behavior. I'm using Windows 98SE, and with the WDM drivers, it sounds fine. However, I have some games that crash with this driver, so I'd rather use the VxD drivers. For some reason, with these drivers, I get an odd reverb effect on anything connected to the Line In. I can't figure out how to disable this. I'm pretty sure it's not a hardware issue since it's fine with the WDM drivers. Does anyone have any ideas?
