First post, by SWZSSR
Hi All
One of my friends has a very special 386 motherboard that I have never seen before. I have hunted all major motherboard websites for its layout/model but had no luck.
Bios doesn’t show anything regarding model/make.
Distinguishable Features
- 16x SIPP Sockets
- Onboard Com/LPT via SIS82C452
- 32KB Cache
- Standard AT Sizing
- 3x 16bit 3x 8bit ISA
I know the chipset is a C&T NEAT, but it has a lot more chips than any other board of that era. My friend believes he pulled it out of a low profile chassis back in the 90s for a 486 upgrade.
Sorry for bad photos, I will take it out the case some point and get decent photos.
5TH / Dual 233MMX / Millennium II 8MB / Voodoo2 12MB
P5A ALI-G / K6-3+@600 / Geforce256DDR / EWS64XL
Thunder 2500 / Dual P3-S 1.4 / 7950GT AGP / Audigy 1
M919-3.4bf / 5x86@180 / Banshee-PCI / Soundscape Elite
AX4GE-Tube / 3.06HT / FX5950Ultra / Tube Audio
Reply 1 of 7, by Deksor
What bios is in there ? Phoenix ? AMI ? Mr BIOS ? Award ?
If it's AMI (or maybe even award), you should have a POST string which can be used to identify it. Can you please show it to us (and/or dump your BIOS using this http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP) ?
Reply 2 of 7, by SWZSSR
Deksor wrote on 2021-07-03, 12:08:
It is a AMI with Low&Hi bios. Here is some photos.
As for dumping the bios, can the tool detect low&hi?
Reply 3 of 7, by Deksor
Unfortunately, no it cannot do that, (I don't think any software dumping tool can do that actually). If you have a TL866 you can dump it that way, otherwise it'd still be better than nothing because it's possible to split the eprom file (now I don't know exactly how the split is made on your board, but that'd be up to the person that might want to restore a missing bios on their motherboard)
Reply 4 of 7, by Horun
The BIOS string # is either 1230 or 1238 (cannot tell) if 1238 indicates a Win Technologies board (AKA: Wintech / Edom / WinTac) but their archives only list MA013/MA014 Opti based 386 board.
never mind, is 1230 and cannot find any info yet
Reply 5 of 7, by Deksor
Yes, unfortunately that ID isn't documented anywhere. That doesn't mean it will never show up though. With UH19 we're planning to make an up to date manufacturer id for POST strings.
Reply 6 of 7, by SWZSSR
Here is a dump of the low and high bios. I used my TLS866, had issues finding S27C256-20N Chips. l found they might be Phillips, tried that and successfully read them. Data may be corrupt.
Also used getrom. Ran AT & XT. Attached.
    SIPP386GETROM.zip
    59.88 KiB
    54 downloads
    SIPP386.zip
    39.92 KiB
    56 downloads
Reply 7 of 7, by megatron-uk
The 64k ATROM from GETROM looks legit. Loads of AMI BIOS strings, visible chipset config options etc.
Almost the first thing in the file is the following string:
SETUP PROGRAM FOR C&T 386 CHIPSET(C)1988, American Megatrends Inc.All rights reserved.1346 Oakbrook drive, Suite-120,Norcross, GA 30093, Phone-(404)-263-8181
https://www.target-earth.net
