Retention Arm Replacements for Slot A/1 CPUs?
First post, by ultra_code
I just took apart a Slot A CPU to replace the TIM between the die/cache and the IHS, and I was wondering if there was perhaps a plastic clip or something I can buy and use in lieu of the original metal retention arms.
Thanks!
Builds
Reply 1 of 24, by luckybob
it sounds like you've borked the original metal one. i think your options are rather limited. its either fix the original clips, or do something drastic.
something drastic, would be to remove the 4 center studs around teh cpu core, and replace them with screws/springs.
Reply 2 of 24, by ultra_code
luckybob wrote on 2021-05-16, 05:13:
I mean, nothing too bad this time around. The clips on my Pentium 2s, though, uh, heh, they could be better off.
I neither have the tools nor knowledge to do such a thing, although perhaps springs and zip-ties (?) or something to push down and retain the springs could work.
Besides finding replacements for the clips, I guess I also could get a general water block and use some string to secure it to the CPU - even less ideal. 😒
Builds
Reply 3 of 24, by luckybob
yea, i suppose if you dont have a drill and a tap/die set. it wouldn't really work.
I bet, you could ask someone with a 3d printer to make a U-shaped v-wedge to grab onto the studs.
Reply 4 of 24, by ultra_code
luckybob wrote on 2021-05-16, 05:56:
Another good idea.
I've been doing a bit of googling and I think I've found a solution (springs + push nuts). However, testing it will take some time, as getting the springs from China will take some time. Will update on results when the springs arrive.
Builds
Reply 5 of 24, by luckybob
i've kept thinking about it.
E-clips, springs and washers.
stack a fiber washer, metal washer, spring, washer e-clip and see if that works
Reply 6 of 24, by ultra_code
luckybob wrote on 2021-05-16, 06:22:
Yeah, e-clips seem basically the same as push nuts except with a cut-out on the side to make them easier to remove(?). As for metal/fiber washers, that's a good idea. Will implement.
Builds
Reply 7 of 24, by BitWrangler
You may also find that some clothing type snapper fasteners will clip on top of the posts there, but not sure if you need more tension than they will hold without popping off.
I had a surfeit of PII 233s back in the day, and I drilled and tapped a S370 sink and put that on with machine screws. Was able to run it at ~290 then., wooo.
Reply 8 of 24, by ultra_code
It has been a while. Mainly due to the fact that the first springs I ordered from China were no bueno, so I had to order more. Also, the push-nuts I bought wouldn't cut it--eclips were the call. The final result used 0.5x5x5mm springs (shorter/thinner-in-diameter ones could in theory, if they exist, since they'd be some weird dimension) and M2 e-clips.
One downside is that the outside metal rods aren't the same as the inner ones, which have an inner gap for e-clips to "clip" onto. With 1mm thermal pads, with only the center four rods acting as retention mechanisms, this results in the CPU card doing a bit of a bend. 😒
I can't imagine it being too serious, and after some time I'd imagine the pads would compress... I hope. If I really need to, I could see if 0.5mm pads would work, but man, it was a pain to get those tiny-ass e-clips on. Would like to not do it again.
Builds
Reply 9 of 24, by luckybob
Id remove those pads on the cache chips. But it looks great!
Reply 10 of 24, by snufkin
the_ultra_code wrote on 2021-06-29, 11:24:
0.5mm was too thin on mine. I thought about adding in some thermal compound to bridge the gap (similar to the thermal goop that was in there originally, which didn't actually make contact on one side), but I pressed some 1mm pads in a vice before using them and that seemed to do the trick.
Reply 11 of 24, by quicknick
Congrats, that looks great! I have to do this on my four Slot A CPUs, but kind of gave up/indefinitely postponed the operation seeing how hard it is to open the cartridges.
Regarding the bending of the CPU card, aren't you going to replace the plastic shell? I believe the four 'receptacles' for the outer metal rods are shaped in a way that pushes against the PCB, thus assuring it stays flat.
Reply 12 of 24, by ultra_code
luckybob wrote on 2021-06-29, 15:40:
How hot do the cache chips get anyways?
quicknick wrote on 2021-06-30, 01:15:
Nah.
Builds
Reply 13 of 24, by ultra_code
Quick follow-up: installed the CPU into my seemingly NOS Asus K7M, and it works fine as far as I can tell. Only issue is CPU temp in-BIOS is incorrectly being reported at 0C, even after some MemTest86 (the heatsink is hot, but I guess that makes sense when the system is chugging 90W from the wall). Is the CPU still not hot enough for the motherboard/CPU sensors to list an accurate value, or could I have damaged the CPU in some way for the sensors not to work? Anyone know where the sensors are anyways?
Builds
Reply 14 of 24, by luckybob
Do these chips have a on-die thermal sensor? I dont know. Because if its zero, it's usually disconnected.
Reply 15 of 24, by Doornkaat
There's a two pin header you connect a sensor to right next to the voltage jumpers. The sensor with leads was not (edited, sry forgot this important word! 😅) included with the mobo and would usually be taped close to the center of the heatsink to get the closest approximation of the core temp.
Reply 16 of 24, by luckybob
yea, thats how i remember things being. P3's were the same way.
i have a few processors where I placed a 10k-ohm thermistor next to the cpu core and plugged it into those sensor connectors.
Reply 18 of 24, by ultra_code
Doornkaat wrote on 2021-07-04, 06:49:
luckybob wrote on 2021-07-04, 06:51:
Wow, really? That's kinda disappointing. I know my Slot 1 Pentium IIIs and even Pentium IIs have on-CPU sensors, so for AMD not to have on-CPU thermal sensors seems strange. Guess AMD was a bit behind in tech.
Builds
Reply 19 of 24, by Caluser2000
Maybe the AMD cpus just never needed a thermal sensor.
