Today I ran the program on two other PCs, one S7 i430VX with AMD K6-2-360 CPU (it's a 400 set as 6X60), the other is a 486-DX2-66 VLB Cyrix CPU (green), both MB have a problem with the L2 cache, only by disabling it the PCs work.
I put some pictures, in the K6-2-360 I had installed the version for Windows, the program works with w95a installed as OS, the only thing is that I no longer see the references with other PCs, and therefore I cannot compare the values obtained.
I'll put the files created with both PCs as soon as I can.
Returning to the K6-2-360, I noticed that the dos version identifies the MB as PCCHIPS M530, in addition to the AMPTRON models, but in fact the MB PCChips is not M530 but is M549, probably the BIOS used will be the same, also because it is unable to identify at startup the CPU as amd k6-xxx, it recognizes it as -MMX 66MHz, instead your program recognizes it exactly, even if the CPU used by me is a CXT (I don't know if I can identify it from the multi 6X).
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
