First post, by Nemo1985
I just received a 1400 tualeron, due not being properly packaged 2 pin just came off (they are not broken the they were just ripped off on the plastic container I received.
According to this picture: https://images3.imgbox.com/07/61/cbBrTnUE_o.gif
One is the VID2, so maybe it's redundant, but the other is IGNNE, which seems important.
Ripped off pins:
52.11 KiB
Cpu:
111.1 KiB
Do you think it will work? If it won't any chance for recovery?
Thanks
Reply 1 of 8, by darry
Nemo1985 wrote on 2021-07-05, 06:04:
I just received a 1400 tualeron, due not being properly packaged 2 pin just came off (they are not broken the they were just rip […]
Ripped off pins:
Cpu:
Thanks
Depending on how much current these pins carry, doing what I did here might work reliably for you too : Broken pin on socket 370 CPU. Still works but is it reliable ?
Reply 3 of 8, by darry
Nemo1985 wrote on 2021-07-05, 06:41:
I readed that topic before trying to ask, I'm not sure I have the skills to do the same, that's the reason I asked if those 2 pins are mandatory.
What I wanted to do was use conductive epoxy to glue the pin back
What I actually did was put the pin in the proper socket hole, then insert the CPU in the socket and then put the cooler on . Everything has been working fine for 4 years . I am not suggesting you try this before knowing more about the purpose and current carrying specs of the said pins, but you be as lucky as I was .
Reply 4 of 8, by Miphee
darry wrote on 2021-07-05, 06:52:
What I actually did was put the pin in the proper socket hole, then insert the CPU in the socket and then put the cooler on.
That's actually a brilliant solution for people with limited soldering equipment/experience. It should probably work with smaller CPUs too that are extremely hard to solder anyway.
Reply 5 of 8, by Nemo1985
That's briliant!
Any advice about what epoxy to use?
I tried the cpu, it apparently works fine. The reset switch works too... The voltage of the cpu is 1.47 according (it should be 1.50) to what the bios says.
Also I need to do an errata corrige, the vid pin is probably used to say to the cpu what the voltage is, more than carring voltage it self.
Reply 6 of 8, by darry
Nemo1985 wrote on 2021-07-05, 07:13:
That's briliant! Any advice about what epoxy to use? […]
That's briliant!
Just to be clear, I did not even use conductive epoxy as it just works without any .
Reply 7 of 8, by Tiido
VID pin is Voltage Identification and it is necessary for getting proper voltage. The slight undervolt will do good if the chip stays stable, less heat is produced.
!IGNNE is for raising FPU error interrupt and it shouldn't matter at all. It used to have proper meaning in hardware where there's a separate FPU but with the FPU integrated the pin shouldn't have any real use unless something tries to simulate an FPU error condition (the pin is an input not an output).
Reply 8 of 8, by Nemo1985
Tiido wrote on 2021-07-05, 07:43:
Thank you Tiido!
Apparently the board always give something less compared to what it should, even with a cpu with all pins it give 0,03 less.
