Reply 620 of 970, by Caluser2000
- l33t
Mumak wrote on 2021-07-05, 07:29:That's right, MSDOS 7.x is no longer the "good old" real mode DOS as it used to be.
Regarding the wrong CPU clock on VIA Eden, I'd need to see the HWiNFO Report and Debug Files (run HWINFO -r -d) to check what might be wrong.
Yes it is. It just has FAT32 support added. Which is dam handy. There should be a directory on the win98 installation CD called OLD DOS with all the programs prior to Dos 7.1 had. Also the Editor is stand alone, free of BASIC. You do the same tasks as MS/PC Dos 6.x if the software will run on it.
Way back the China Dos Union made a distribution of Dos 7.1 with a ton of freeware utilities.
Your preogram should run on Dos 7.1 exactly the same as prior Dos versions.
IMSs Real32 Dos is a different mater. It is a true 32-bit operating system that can have multiple user unlike PC/MS Dos 7.1 You have the choice of multi-user or single user doing the installation routine. Only one MS Windows 3.x session though. Version 7.92 from 07-01-01 has fat32 support.
MickySoft just decided Dos 7.1 wasn't going to support any cpu below a 386. https://en.wikipedia.org/wiki/MS-DOS_7 There is no reason that 286s a below can't support fat32. I've seen FreeDos compiled kernals to do just that on XT class computers that support the fat32 file system. http://wiki.freedos.org/wiki/index.php/Hardwa … e_compatibility
Disk images http://jorisvr.nl/article/freedos https://sites.google.com/site/rugxulo/
It's really there to boot strap Win 9.x and supply Dos backwards compatibility.
