My never ending Tandon 286 project
First post, by GuillermoXT
Since i took the 286 from the house of my Parents witch was not used for many years to my flat last year i was modifying it one after another.
This is how it looked like at the beginning
1.84 MiB
Amd 8MHz
1mb ram onboard with memory remap
5.25 Floppy with 34pin cable connected to the onboard 50pin port
9pin EGA/CGA graphics card
40MB RLL HDD + Controller
538.77 KiB
113.06 KiB
First i sent my PSU to a friend to make sure it´s still OK - It was and i got a replacement for my BIOS battery
Then i replaced the noisy fan with a very silent Noctua
71.88 KiB
And used Retrobright on the plastic parts to restore the color from factory
99.84 KiB
My Retrosystems:
PIII on GA-6BA running Win98SE
AMD K6 233 on GA-586HX with Win95
Tandon 286-8MHZ Running DOS 6.22 on XTIDE-CF
M326 486DLC + 4c87dlc (Dos+Win3.11)
ECS UM4980 AMD DX2 80 5V (Dos & Win3.11)
Reply 1 of 24, by GuillermoXT
I exchanged the original ega/cga graphics from the XT-Slot with an 16bit ISA Trident TVGA 9000a - but it took some time to notice that the "bios autodetect" jumper has to be set as DISABLED otherwhise you might keep stuck on a bootloop 😉
Here a video
https://youtu.be/klV2OidLHVY
After that I realized that the floppy drive was faulty but I got lucky to find a package of three drives very soon for a small amount of money.
336.56 KiB
The original Floppycable has only edge connectors so i hooked another one with additional 34pin connectors to the original 50pin connector
275.25 KiB
136.89 KiB
Yes the newer cable allows me to use the 5.25 and the 3.5 inch floppy drives ! 😀
394.58 KiB
Then i found this interesting XMS card with 3mb witch seemed to be built for a Siemens Nixdorf and after configuring it i got 4MB of ram on the counter when turning the PC on 😉
110.71 KiB
My Retrosystems:
Reply 2 of 24, by Caluser2000
Co0l. Well done. The more 286 goodness in vogons the better ...😉
When /if the mfm hdd dies on you I recommend getting a XT-IDE card for use with more modern hdds, CF/SD cards. I have one in my XT-Turbo system with a 2gig spinning rust drive. Oh I see have one according to your signature.
It may even run GeoWorks Ensemble 1.x ok. Gem should be ok as well. Forget any windows version prior to v3.
    618.39 KiB
Reply 3 of 24, by GuillermoXT
The next turn was that i thought "why do i have to keep stuck with only 40MB and the Bios only supports up to 170mb"?
The solution: an XTIDE-CF card +4 Gigabyte CompactFlash released by Sergej malinov and completed by @matze79 inserted in the 8bit Slot of the previously used graphics cga/ega card
80.3 KiB
He also pre-installed MS-DOS 5.0 for me so i could start immediately 😀
The first few weeks i used a CT1600 SBpro2 to have Sound on the Tandon for the first time after more than 30 years!
Later i exchanged the SBPro2 with an SB16 CT2940 with integrated IDE-INTERFACE and managed to get it running thanks to Unisound programmed by @Jazefox ✌
On the front of the 5,25 adpter for the 3,5 Floppy i had some space for hooking up an external LED for the HDD activity of the CF card.
Since I swapped the RLL HDD out there was then space on the bottom for the 4xspeed CD Drive witch I connected to the IDE-INTERFACE from the SB16.
1.04 MiB
The last upgrade until now is the ISA network Card with RJ45 connected to my daily pc so I could use mTCP and Filezilla to copy some files very easily and faster than a connection via Nullmodem on RS232 👍
910.68 KiB
297.15 KiB
My Retrosystems:
Reply 4 of 24, by Caluser2000
Looks like you have certainly done your home work.
I've just altered my sig....😉
Reply 5 of 24, by GuillermoXT
Caluser2000 wrote on 2021-07-07, 18:15:
Yes I replaced the hdd already with the xtide-CF4 card just in case of....and because I wanted much more space AND a silent 286 😅
There were so many things I changed and it doesn't fit in only one post 🤣🤣
......And it's still not finished😏
My Retrosystems:
Reply 6 of 24, by GuillermoXT
Caluser2000 wrote on 2021-07-07, 18:48:
Thanks 😊
My Retrosystems:
Reply 7 of 24, by GuillermoXT
The reason why the CD Drive was not attached is because the drivers for CD load on config.sys before unisound is loaded witch activates also the IDE-INTERFACE from the Soundblaster.
Shown here
940.96 KiB
With Devload.com copied on your bootup-drive you can load CD drivesrs after unisound is loaded and so your IDE interface.
Here is how it looks like now
344.71 KiB
Here on the photo of config.sys I forgot to delete the line with the VIDE-CDD because now it's loaded by Devload in Autoexec.bat ☝😉
283.36 KiB
248.2 KiB
My Retrosystems:
Reply 8 of 24, by Jo22
Just love 80286 systems! ❤️
This one seems to be in a fine condition, too!
If the system is up and running, please consider installing 2MB, at least.
Or 4MB, if possible. This makes GUIs running much smoother. 😀
Edit: Never mind, just noticed that's already the case.
Maybe adding an UMB or EMS card could be useful then.
But that's optional, of course.
Reply 9 of 24, by GuillermoXT
Jo22 wrote on 2021-07-07, 20:14:
Just love 80286 systems! ❤️ This one seems to be in a fine condition, too! […]
I'm glad you like it. 😊
XMS seems to be used more often than EMS.
In addition, I don't have enough slots left otherwise it would be perfect😉
I have a proprietary slot for a 4mb extended memory module here (total 5mb ram without the XMS card), but I haven't been able to find it yet ... so if someone knows something 😁🙏
Here is the still empty place looking like a wider ide connector 🙂
195.17 KiB
218.75 KiB
My Retrosystems:
Reply 10 of 24, by Caluser2000
Here's a pic of my Zenith 286LP Plus(286/12) with 8megs of ram. Runs Dos, MS Windows 31, nic packet drivr, winpkt, and a few straight Dos applications Like you I'm using new technollogy to enhance it. It has an external Backpack CD reader, external LS120 drive daisy chained to the Backpack, nic as well as a nice white beige Packard Bell FT700 LCD Monitor. I pinched the Windows for Workgroup 3.11 FPT and TELNET clients and their help files. When Windows loads it starts the Trumpet Winsock for TCIP. Once in Windows I fire up the IRC client PIRCH to access my favourate IRC channels....😉
    663.08 KiB
Reply 11 of 24, by Caluser2000
GeoWorks 1.x works just fine on my XT-Turbo with 640k. I'ts real mode application.
I use it on my original 286/16 with DRDos 6.0 for at least a year in the early '90s when I was just learning about x86s and computers in general. It has more functionality out of the compared to MS Windows 3.x....😉
Which exactly why I purchased it over MS Windows 3.x. You see being new to the pc game I did my research rather than taking notice of all the advertising garbage at the time.
Reply 12 of 24, by GuillermoXT
Caluser2000 wrote on 2021-07-07, 20:34:
Wow this is pretty cool🙂👍
Would DR-Dos be able to use the 3mb xms so in total programs could use it as conventional memory?
Even with the card Dos tells me having less than 1mb of conventional memory
1.15 MiB
1.3 MiB
My Retrosystems:
Reply 13 of 24, by GuillermoXT
Witch GeoWorks Edition should i test/use?
Currently I am working with Volcov Commander (NC clone)
My Retrosystems:
Reply 14 of 24, by Caluser2000
GeoWorks 1.x will run fine on MS Dos 5.0. Look in your Dos directory there should be a file called emm286.exe. Load that file in you 286 config.sys file on start up ansee if the sysrem sees the extra ram. I run MS Dos 5 of my 286 as well and put a copy of it's config.sys. Just use Dos edit command to add the entry. Just remove the rem entry on mine.and start it with Device= etc
    625.67 KiB
Reply 15 of 24, by Caluser2000
GuillermoXT wrote on 2021-07-07, 21:58:
GeoWorks Essemble 1.2 They redid the code in version two and that is a bit slower.
Reply 16 of 24, by Caluser2000
Here's my 286s' autoexec.bat file...😉
    576.69 KiB
Reply 17 of 24, by Jo22
I would recommend using the latest version that runs on a 286.
Or a PC/GEOS with 2.x API level, at least.
From what I heard, the application support for version 1.x was very medicore.
For the later versions, however, there are quite some useful programs.
Astronomy programs, Web Browsers, IRC clients, E-Mail clients, FLI/FLV players, BASIC Compilers etc.
Animation Player for PC/GEOS:
https://www.youtube.com/watch?v=A0_Ziif3DEQ
Anyway, Caluser2000 surely knows more about PC/GEOS, so have a look at his advices.
- I was more of a GEM and Win2.x/3.x user, hah. 😅
Reply 19 of 24, by GuillermoXT
Caluser2000 wrote on 2021-07-07, 22:01:
I remember not having emm286 but 386 wich is meant to work on 386 and up.
Your startup files look very different from mine.
I've heard that emm286 is a special mod from the 386 edition and it could slow down my system or am I wrong? 🤔🙂
My Retrosystems:
