First post, by BitWrangler
Hi folks,
So I have a lot of 56k and other modems around, and it struck me last night, what if there's a possible use for them? It's all dependent on how the flash memory firmware features are implemented. If they are at an address and memory location on the PC's bus, then even if one has to crosswire pins close to the edge connector, it could be possible to set them to a useful address... like for XTIDE. Google's artificial stupidity seems to have dropped a further dozen IQ points in the last few months, and keeps "helpfully" giving me stuff about how to plug flash drives into my router, when modem and flash appear in the search terms. However, I was getting hints that it's more like serial programming an arduino, in that the flash is in the onboard micro. Should this be the case in all models, I guess this is a bit of a non-starter. I wonder if the earlier flash upgradeables were more like a ROM on the bus though. I think it started when 14.4k standards were hanging in mid-air unratified, so they pushed out V32 turbo hardware with flash to upgrade when standards caught up. Anyway, any ideas in this direction?
Reply 1 of 11, by weedeewee
since most internal phone line modems are presented to the computer as a standard serial port there tends to be no need whatsoever to have direct bus access to a rom.
Do not ask Why !
Reply 2 of 11, by BitWrangler
Yeah, I guess there's no x86 code to execute from the firmware, it's internal code... but then we got winmodems to fog things up, but I guess they just put it all in the drivers.
Reply 3 of 11, by weedeewee
winmodems were mostly DSP-like hardware where the firmware got loaded by the drivers and the cpu of the mainboard had to do the rest of the processing.
most of them were bloody horrible devices.
Do not ask Why !
Reply 4 of 11, by Jo22
Old serial modems sometimes have another interesting feature.
The "voice" models allow for playing back wave form samples.
This was intended for the use as an answering machine,
but maybe this could be useful for other things, too? 🙂
Reply 5 of 11, by BitWrangler
Yes, could be got on internals too though. My wife's PC when I met her had this not full length, but long ISA card with a soundcard and voice modem semi integrated, they still seemed to have separate sound chips though. There was only some clunky win95 software for it for answering machine services. I don't know if a lot of those implementations were proprietary or something, but there never seemed to be a consumer piece of software that tied all the functions together in a good way, you just seemed to have these halfass apps written by ppl who were used to shoving bits down serial connections and not a lot else. Also it seemed voice modem stuff never really carried over into good win98 support, and voice modems seemed to die out before 56k.
I had some odd convos on about half a dozen forums, bulletin boards and lists dedicated to linux telephony about a decade ago, thinking that there must be some way to use them in linux, they all went about like...
Me: So I have this voice modem with answer function so it works as an answering machine...
Them: no it can't
Me: really it does it's got built in sound features which...
Them: that only came out a couple of years ago on the XB2864whatever PBX
Me: I don't need a PBX I just want digital voicemail on...
Them: yeah so you need a PBX system
Me: Right, okayyyy, so if I put a bunch of voice modems into a linux box...
Them: No, a real PBX
Me: but the modem has voice and answering features I want to use on linux.
Them: No it doesn't.
Reply 6 of 11, by weedeewee
Never looked much into it, though also pondered about if it was possible to use as voicemail/number logging.
Seems like there's a whole wiki page... https://en.wikipedia.org/wiki/Voice_modem_command_set
the number logging for ISDN was easy. for analog lines it seemed like my local operator didn't support it so that option went down the drain due to not supported... Wondering if it there even was a modem that supported it on analog lines. I think there was a way, though, yeah, hardly supported, I guess.
oh well.
off to read the wiki.
Do not ask Why !
Reply 7 of 11, by dionb
weedeewee wrote on 2021-07-08, 14:49:
The earlier 'hardware' DSPs were potentially more interesting, things like IBM's mWave chip. That really did the processing on the card. However it was RAM (on card) + driver, not ROM based, so probably not useful for what OP has in mind.
Reply 8 of 11, by weedeewee
dionb wrote on 2021-07-09, 19:26:
indeed. 😀
Do not ask Why !
Reply 9 of 11, by lolo799
I still have the USrobotics modem bought in the 90s in its box somewhere, it could work on its own to store voice and fax messages on flash memory while the computer was off.
It might have been possible to use it as an automatic answering machine offering multiple choices to the caller as well as listen to voice messages remotely...
Reply 10 of 11, by weedeewee
lolo799 wrote on 2021-07-09, 19:47:
US Robotics Sportster Message, I think was the model you're referring to.
Do not ask Why !
Reply 11 of 11, by lolo799
Something like that yes, Message Plus maybe, it was possible to upgrade the flashrom to support whatever happened between the two competing standards at the time.
