First post, by Chadti99
See the 2nd post but the fix was disconnecting pin21.
I’ve used one of these before in a Biostar486 board and it worked great. Now I’ve tried it on another brand of 486 board(GA-486AM 2.2) and it will save my settings after a soft reset but not after a power cycle. Is the part defective or possibly something else going on? Was thinking maybe there was a cmos reset jumper closed but I can’t find one on the board. I’ve swapped for a known good battery as well.
Reply 1 of 3, by Horun
Which exact Dallas chip was the original ?
There are different versions of the DS12887 including DS12887A, DS12C887, DS12C887A and they are not exactly the same.
114 Bytes of General-Purpose, Battery-Backed RAM DS12887, DS12887A (113 Bytes in the DS12C887 and DS12C887A)
RAM Clear Function DS12885, DS12887A, and DS12C887A. My guess is that Pin 21 on your board is grounded causing the CMOS to clear when powered down:
"RCLR must be forced to an input logic 0 (ground) during battery-backup mode when VCC is not applied."
Pull the new RTC and gently bend pin 21 out a bit so it is not inserted into the socket and see what happens.
Reply 2 of 3, by Chadti99
Horun wrote on 2021-07-10, 21:12:
Which exact Dallas chip was the original ? There are different versions of the DS12887 including DS12887A, DS12C887, DS12C887A […]
My man! You are a life saver. It was using DS12887 and looking at the original part, pin21 wasn’t connected. I bent pin 21 back as instructed and we’re in business, thanks so much!
Reply 3 of 3, by Horun
Great ! Glad it was something simple.
