Help to identify 386 mobo and manual
Reply 20 of 31, by mrwho
Here's one:
attachment%5D
“Hey, you sass that hoopy MrWho? There's a frood who really knows where his towel is."
My home retro drivers repository: ftp://retro:drivers@mrwho.duckdns.org
Reply 21 of 31, by pentiumspeed
That's 386SX.
Cheers,
Great Northern aka Canada.
Reply 23 of 31, by mrwho
Deksor wrote on 2021-06-18, 20:03:
More precisely, it's an ECS 8517
http://www.win3x.org/uh19/motherboard/show/6803
Hello.
If you're refering to the board I got, no it's not - the one you mentioned has one 8-bit slot, and the one I have has none - they're all 16-bit.
Luckybob seems to have nailed it right, though...
I connected two-CR2032 in series to the Ext batt connector, but it's not keeping the BIOS data. Is it possible to check, with the multimeter, if the battery power is reaching the BIOS chip?
Thanks.
Reply 24 of 31, by megatron-uk
Some boards have a jumper which needs to be moved in order to go from the onboard to external battery. Is there a jumper close by your external battery connector?
https://www.target-earth.net
Reply 25 of 31, by Deksor
You're right, it's this one : http://www.win3x.org/uh19/motherboard/show/5482
But I think it's still an ECS 8517, just not the same rev. Can you turn it on and show us the POST string (and eventually make a BIOS dump and share it with us ?)
Reply 26 of 31, by MotoPete
mrwho wrote on 2021-06-22, 12:49:
Thanks.
It would be easier to solder a 20mm button cell battery holder directly to the board, in place of the original battery, and then insert a LIR2032.
If you want to keep your external battery however, this thread may assist:
https://www.eevblog.com/forum/repair/how-to-t … n-oscilloscope/
In particular this diagram, although obviously your board will likely vary according to its own design:
I hope that helps!
Reply 27 of 31, by mrwho
Deksor wrote on 2021-06-22, 13:07:
It's working now - I (wrongly) assumed the pin 1 of the ext bat conector would be the positive, but I was wrong. I inverted the connector, it is now holding the configuration.
Here are the captures of the boot screen.
I can dump the bios, as soon as I order a couple of ide2sd adapters, and get my hands on some ISA HDD controller cards.
Reply 28 of 31, by mrwho
I've got it fully working at last. How can I dump the BIOS and where should I send it to?
Reply 29 of 31, by jesolo
mrwho wrote on 2021-07-10, 18:39:
Easiest way to do this is with a software utility - one like Navrátil System Information (NSSI 0.60). It has an option to save your BIOS ROM contents.
Just make sure that, in your BIOS settings, Shadow RAM is temporarily disabled.
There might be other utilities as well (you could even try AMI's own flash utility), but I'm sure other users can pitch in with more suggestions.
Reply 30 of 31, by mrwho
jesolo wrote on 2021-07-11, 17:40:
Easiest way to do this is with a software utility - one like Navrátil System Information (NSSI 0.60). It has an option to save y […]
Thanks. Will try it tomorrow.
Is there a repository where I can upload it to? I can also place it on my ftp server, if it helps anyone...
Reply 31 of 31, by jesolo
mrwho wrote on 2021-07-12, 22:01:
Thanks. Will try it tomorrow. Is there a repository where I can upload it to? I can also place it on my ftp server, if it help […]
You can just upload the file here (as a zip file) and quote @deksor's original request.
