First post, by candle_86
This was the solution, wife figured eletrical tape made it look better
Reply 1 of 5, by jakethompson1
Once you are in the realm of using an ATX-to-AT converter on the power supply, another option is to replace the momentary power switch in an ATX case with a latching one. I've found the E-Switch TL2285EE to fit many cases. You would have to solder wires between the correct pins, and the wires on the converter intended to interface with the original (AT) power switch.
Reply 2 of 5, by candle_86
how come i didnt know about this, now i feel stupid, oh well next time i suppose
Reply 3 of 5, by darry
Heat shrink tubing instead of electrical tape would be more durable and likely more aesthetically appealing.
Reply 4 of 5, by candle_86
darry wrote on 2021-07-16, 03:02:
my wife made it, dont want to upset her 🤣
Reply 5 of 5, by maxtherabbit
jakethompson1 wrote on 2021-07-16, 01:50:
E-Switch TL2285EE
Holy shit thanks for posting this. I went through hours of searching for a part number for a suitable replacement and ultimately failed. (The project only was completed since Eep386 sent me a used switch harvested from an old case)
