Reply 660 of 884, by PC@LIVE
- Oldbie
Today I tried the program on another PC, it has an i430VX chipset and a 166MHz CPU, the RAM is 32MB, unfortunately despite having tried to increase it in the past, I could not get more read.
I ran the program and created the LOG and DBG files, I am attaching them here.
The PC I used long ago to test various CPUs, at the same frequency (166), in this way I could understand what differences there were between them, I used a P.MMX a K6 and a MII, for the latter as you can see from the results I used a MII-300 lowering the frequency from 233 to 166.
If I wanted I could use other cpu, for example a K5 or an IDT-C6, but these are single voltage (it would not be a problem), the K5 works at a lower frequency around 116MHz, the IDT could perhaps have problems of recognition by the BIOS, but I remember updating it to see if it read more RAM.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
