First post, by wd
Rank DOSBox Author
DOSBox Author
Small workaround (10 bytes). Do NOT use this fix for any other game.
In order to use it, just start it before running Mickey's Space Adventure.
You need to re-run it when you restart dosbox, but you don't have to
re-run it in one session (it's no tsr though).
    mickey_tandy_fix.zip
    126 Bytes
    332 downloads
Reply 2 of 2, by wd
Rank DOSBox Author
DOSBox Author
Because they use it to check where the video area is, which is at the
top of the 640k.
ah/al on load are some fcb validity identifier, don't know if later dos versions
would set anything !=0 at all.
