First post, by gerry
What is the complete vintage system (that you could just switch on and use) that you actually don't use much at all?
how often do you use it? Why is it that you don't use it often?
For me it's a bunch of systems but there is one complete P1 166 mmx that I've had from new, that works great and that I hardly ever use
last time was a year ago and that was because i swapped the original 2gb drive for a 4gb one and installed 98se instead of 95, i had an idea of later installing a USB card but haven't as yet. After testing that it worked well and that things like Doom & Duke worked perfectly and a couple of windows apps too I left it alone.
The reason is partly that its old and I don't want to break it! Mostly though it's that I have more powerful recent systems that do everything it does and more, and then there's dosbox and source ports that mean even games that may have setup issues on later systems are just fine
I'm still going to keep it though! 😀
